keyboard shortcuts for 50% view, etc
keyboard shortcuts for 50% view, etc Gary Aitken 26 May 02:17
  keyboard shortcuts for 50% view, etc Richard 26 May 04:08
   keyboard shortcuts for 50% view, etc Gary Aitken 26 May 14:41
    keyboard shortcuts for 50% view, etc Richard 26 May 23:28
  keyboard shortcuts for 50% view, etc Liam R E Quin 26 May 04:13
   keyboard shortcuts for 50% view, etc Richard 26 May 12:08
Gary Aitken
2014-05-26 02:17:28 UTC (almost 11 years ago)
I have not been able to get the keyboard shortcuts for < 100% view (2, etc.) to work since as long as I can remember. The ones for 100% and greater ('1', '2', etc.) seem to work fine.
If I activate the shortcut key editing dialog and try to set the shortcut manually, e.g. 2 for 50%,
instead of displaying 2 it displays "@" (which is the normal character for 2 on my keyboard) and it works fine.
Does anyone else have the same issue?
Is there something I am missing, or are the shortcuts simply not working in my (fbsd) build?
Gary
Richard
2014-05-26 04:08:02 UTC (almost 11 years ago)
I get the same behavior, running GIMP 2.8.10 on Win32 XP. (Though in my case I generally zoom via mousewheel not keyboard so I wouldn't have noticed.)
Bug? Shift+2 == @, but you'd think that all keyboard shortcuts should use the actual scan code for the key(s) and not its logical input value.....
Date: Sun, 25 May 2014 20:17:28 -0600 From: gimp@dreamchaser.org
To: gimp-user-list@gnome.org
Subject: [Gimp-user] keyboard shortcuts for 50% view, etc
Gary
Liam R E Quin
2014-05-26 04:13:18 UTC (almost 11 years ago)
I rebind those to brish size and hardness, but the { and } bindings also dont work for me as shift-[ and shift-} but only as { and }
Mageia GNU/Linux™ Operating Environment*
Liam
* Linux is a trademark of Linux Torvalds.
Richard
2014-05-26 12:08:09 UTC (almost 11 years ago)
Aha, here we are (I think).
https://bugzilla.gnome.org/show_bug.cgi?id=677707
To: gimp@dreamchaser.org
Date: Mon, 26 May 2014 00:13:18 -0400 CC: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] keyboard shortcuts for 50% view, etc
Mageia GNU/Linux Operating Environment*
Liam
-- Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ Ankh: irc.sorcery.net irc.gnome.org freenode/#xml
Gary Aitken
2014-05-26 14:41:02 UTC (almost 11 years ago)
Thanks for the verification.
I say bug because it is, according to the Edit/Keyboard Shortcuts menu/ +View dialog, already assigned.
How the mapping is done would depend on where in the stack one did it. I could see a case for doing it either way.
Gimp has an interesting issue for shortcuts, I think (I'm not familiar with the code) Chars/keycodes are not mapped the same all the time. You want normal characters, such as @, when entering text; but the rest of the time you want it to be a shortcut. Which means it has to be mapped in two different ways depending on the state. It obviously does it correctly / according to the docs/interface for some characters, but not others.
If I activate the shortcut key editing dialog and try to set the shortcut manually, e.g. 2 for 50%, instead of displaying 2 it displays "@" (which is the normal character for 2 on my keyboard) and it works fine.
Thanks.
Richard
2014-05-26 23:28:35 UTC (almost 11 years ago)
Date: Mon, 26 May 2014 08:41:02 -0600 From: gimp@dreamchaser.org
To: strata_ranger@hotmail.com; gimp-user-list@gnome.org Subject: Re: [Gimp-user] keyboard shortcuts for 50% view, etc
Thanks.
Actually, on closer inspection it appears to be this one instead: https://bugzilla.gnome.org/show_bug.cgi?id=676494
