Problem importing raw Minolta and Sony files
13 of 15 messages available
Problem importing raw Minolta and Sony files Jeffery Small 05 Apr 02:43
  Problem importing raw Minolta and Sony files Gary Aitken 05 Apr 03:34
  Problem importing raw Minolta and Sony files Alexander Rabtchevich 05 Apr 05:34
   Problem importing raw Minolta and Sony files Jeffery Small 05 Apr 08:31
    Problem importing raw Minolta and Sony files Alexander Rabtchevich 05 Apr 08:55
     Problem importing raw Minolta and Sony files Jeffery Small 05 Apr 19:11
      CAOW9c=-oDGLg-FUduta0b-rL8T... 05 Apr 20:15
       Problem importing raw Minolta and Sony files Jeffery Small 05 Apr 20:11
        CAOW9c=-xG8jCtTbVLn8=Yo-Fcp... 06 Apr 02:04
         Problem importing raw Minolta and Sony files Jeffery Small 06 Apr 02:00
          Problem importing raw Minolta and Sony files Partha Bagchi 06 Apr 03:08
        Problem importing raw Minolta and Sony files Patrick Shanahan 05 Apr 20:38
        Problem importing raw Minolta and Sony files Partha Bagchi 05 Apr 21:05
        Problem importing raw Minolta and Sony files Gary Aitken 05 Apr 23:38
      Problem importing raw Minolta and Sony files Partha Bagchi 05 Apr 20:01
Jeffery Small
2014-04-05 02:43:10 UTC (about 11 years ago)
Ubuntu 13.10 system running on an Asus U56E system UFRaw ver. 0.19.2
Dcraw ver. 9.19.1
GIMP ver. 2.8.6
Darktable ver. 1.2.3
Shotwell ver. 0.15.0
I reported on this a long while ago and then got very busy with other things. This is a follow-up with details.
When attempting to load Minolta (mrw) and Sony (arw) raw image files into GIMP, UFRaw is not properly processing them. The following webpage has images which demonstrate the problem:
http://smallthoughts.com/photos/misc/GIMP/index.html
The raw files are being imported with distorted color and contrast. However, as the additional images show, other programs such as Darktable and Shotwell are importing and displaying these files properly.
Has anyone else been experiencing similar problems, and is there any known solution?
Regards.
Gary Aitken
2014-04-05 03:34:16 UTC (about 11 years ago)
Dcraw ver. 9.19.1
GIMP ver. 2.8.6
This is kind of a shot in the dark. I don't know anything about shotwell, and not much about darktable. But I know darktable automatically applies an exposure correction curve to the raw file when it imports it, and ufraw does not (unless you set one as the default). You might look at the exposure correction curve darktable applies and see what it looks like when you apply a similar curve in ufraw. There may be other automagic things darktable does in regards to color; not sure.
2014-04-05 05:34:24 UTC (about 11 years ago)
Hello.
Darktable applies RGB camera curve, uses "enhanced" camera color matrix and applies a little sharpening by default.
Dcraw ver. 9.19.1
GIMP ver. 2.8.6
Regards.
With respect,
Jeffery Small
2014-04-05 08:31:34 UTC (about 11 years ago)
Gary Aitken and Alexander Rabtchevich suggest that Darktable (and possibly Shotwell) are applying corrections that improve the display of the raw image. This is true, but in Darktable you can select the "0 - original" image without the sharpening and curve correction and the image is still very presentable, unlike anything that UFRaw is presenting. I can open the raw images using the software provided by Minolta and Sony and the images look fine, but these tools run only on Windows and I really want the GIMP plug-in feature that UFRaw provides.
After opening in UFRaw, the initial settings are so bad that I am unable to correct the picture to create anything close to a usable image.
Are other Minolta/Sony users seeing similar results, and don't Cannon, Nikon and other raw-file users see reasonable images when they use UFRaw?
Dcraw ver. 9.19.1
GIMP ver. 2.8.6
Regards.
With respect,
2014-04-05 08:55:37 UTC (about 11 years ago)
When you look at an imported image in darktable without applying any corrections, the program shows you the embedded preview, which was made by the camera itself with all the corrections it (the camera) would made with the original RAW when converting it to jpg. If you applyin UFRaw a camera curve, similar to the one in darktable, you will see the similar result...
With respect,
Jeffery Small
2014-04-05 19:11:52 UTC (about 11 years ago)
Alexander Rabtchevich writes:
It's true that the lion image imported into UFRaw is terribly over exposed, but that is something that UFRaw is doing to the raw data. The original image has proper exposure which was confirmed at the time the picture was shot as well as the proper exposure from the companion JPEG image (I shoot RAW+JPG). In UFRaw the histogram is shoved completely to the right edge of the spectrum and there is no way to use this tool to fix the picture as most of the image detail is already lost. When I open the same file in the DiMAGE Image Viewer software from Minolta (on a Windows XP machine), the raw image looks just fine and can be tweaked.
So I have to assume that this is a serious bug in UFRaw and I have reported it as such. I'm just confused that I have not heard other people complaining about this problem.
Jeff
Partha Bagchi
2014-04-05 20:01:25 UTC (about 11 years ago)
Can you provide an example image to confirm this?
Thanks, Partha
about this problem.
Jeff
Jeffery Small
2014-04-05 20:11:26 UTC (about 11 years ago)
Partha Bagchi writes:
Sure. Let's use the clouds photo since it is a more modern Sony format and pretty dramatically shows the loss of information. Point your browser here:
http://smallthoughts.com/photos/misc/GIMP/clouds.arw
and save the image. This is a 24-Mb image file taken with an Alpha a77 camera.
Thanks for looking at this. Let me know if I can provide any additional info.
Jeff
about this problem.
Jeff
--001a11c2ef8064e2f704f65119ee
Content-Type: text/html; charset=ISO-8859-1 Content-Transfer-Encoding: quoted-printable
Can you provide an example image to confirm this?= Thanks,ParthaOn Sat, Apr 5, 2014 at 3:11 PM, Jeffery S= mall <jeff@cjsa.com> wrote:
Alexander Rabtchevich <alexander.v.rabtchevich@gmx.net> wr= ites:
>corrections, the program shows you the embedded preview, which was made=
>by the camera itself with all the corrections it (the camera) would mad= e
>with the original RAW when converting it to jpg. If you applyin UFRaw a=
>camera curve, similar to the one in darktable, you will see the similar=
>result...
It's true that the lion image imported into UFRaw is terribly over expo= sed,
but that is something that UFRaw is doing to the raw data. =A0The original image has proper exposure which was confirmed at the time the picture was shot as well as the proper exposure from the companion JPEG image (I shoot RAW+JPG). =A0In UFRaw the histogram is shoved completely to the right edge of the spectrum and there is no way to use this tool to fix the picture as most of the image detail is already lost. =A0When I open the same file in t= he
So I have to assume that this is a serious bug in UFRaw and I have reported=
it as such. =A0I'm just confused that I have not heard other people com= plaining
about this problem.
Jeff
List address: =A0 =A0gimp-user-=
list@gnome.org
List membership: https://mail.gnome.org/mailman/listinfo/gimp-use= r-list
List archives: =A0 https://mail.gnome.org/archives/gimp-user-list
--001a11c2ef8064e2f704f65119ee--
Patrick Shanahan
2014-04-05 20:38:35 UTC (about 11 years ago)
* Jeffery Small [04-05-14 16:15]:
Jeff
about this problem.
Jeff
>result...
about this problem.
Jeff
list@gnome.org
The image provided when opened with auto whitebalance displays a heavy magenta cast but looks quite average when daylight whitebalance is applied and even better when exposure is pushed to ~2.0. Perhaps you have some screen color correction or other saved parameter skewing ufraw.
I see no particular problem besides a lot of un-needed html bloating a text function.
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Partha Bagchi
2014-04-05 21:05:03 UTC (about 11 years ago)
Can you also put the jpg you shot since that tells me what you are expecting to see?
As an aside you may want to visit Dave Coffin's page and read the FAQ especially about gamma and linearity.
Thanks, Partha
Jeff
made
exposed,
was
shoot
as
the
reported
about this problem.
Jeff
this?=
Thanks,Partha
class=3D"gmail_extra">
br>On Sat, Apr 5, 2014 at 3:11 PM, Jeffery
S=
mall <
target=3D"_blan=
k">jeff@cjsa.com> wrote:
margin:0 0 0
.8ex;border-left:1p=
x #ccc solid;padding-left:1ex">Alexander Rabtchevich <
href=3D"mailto:=
alexander.v.rabtchevich@gmx.net">alexander.v.rabtchevich@gmx.net>
wr=
ites:
any
made=
mad=
e
a=
similar=
>result...
expo=
sed,
original
br>
was
r>
shoot
br>
edge
br>
as
br>
t=
he
the
reported=
com=
plaining
about this problem.
Jeff
List address: =A0 =A0mailto:gimp-user-list@gnome.org
">gimp-user-=
list@gnome.org
List membership:
https://mail.gnome.org/mailman/listinfo/gimp-us=
er-list" target=3D"_blank">
r-list
List archives: =A0
https://mail.gnome.org/archives/gimp-user-lis=
t" target=3D"_blank">https://mail.gnome.org/archives/gimp-user-list
Gary Aitken
2014-04-05 23:38:53 UTC (about 11 years ago)
Looks like a normal image when opened here (fbsd, ufraw 0.19.2). Underexposed, but can be brought up to 1.49 w/out any overexposure blinkies. Clouds have lots of definition. WB (Camera WB) looks fine. A little *tiny* bit of purple fringing; I'd be delighted if all mine had that little.
You don't have the color profile, gamma, and linearity set to something strange, do you? If I set to no profile, gamma=0.45, linearity 0.1 all looks good.
Jeffery Small
2014-04-06 02:00:05 UTC (about 11 years ago)
The jpg images look very much like what you see in the Darktable images provided on the webpage.
Antonio Montagnani and Patrick Shanahan also provided feedback regarding loading my test image into UFRaw. Thank you all for the valuable feedback. I admit to certainly not being well versed in using UFRaw and appreciate all the pointers being provided.
One thing I had missed before but do see now, is a warning symbol next to the white balance button. This does not appear for the Minolta .mrw images but seems to always display for the Sony .arw files. When you hover over it, it states "Cannot use camera white balance." That is why Auto is being selected in place of "Daylight". It makes me wonder what other raw file data is not being processed by UFRaw for these types of files? And I wonder if there is something particularly amiss with the Ubuntu build of UFRaw on my system? When others load the sample file, are you seeing a better image than the one I have posted, prior to making any corrections? When you load other types of raw images, does UFRaw display them close to the accurate (i.e., camera) settings? If so, what version of UFRaw and what type of system/OS are you using?
Thanks again for all the valuable help.
Jeff
>> here:
>> camera.
>> info.
>> Regards,
>> Jeff
>> made
>> >> >result...
>> exposed,
>> was
>> shoot
>> as
>> the
>> reported
>> >> complaining
>> >> about this problem.
>> >> Regards,
>> >> Jeff
>> >> _______________________________________________
>> >> gimp-user-list mailing list
>> >> List address:    gimp-user-list@gnome.org
>> >> List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
>> >> List archives:   https://mail.gnome.org/archives/gimp-user-list
Can you provide an example image to confirm >> this?
Thanks,
Partha
> class=3D"gmail_extra">> >br>
On Sat, Apr 5, 2014 at 3:11 PM, Jeffery >> S= >> >mall <> target=3D"_blan= >> >k">jeff@cjsa.com> wrote:
Alexander Rabtchevich <> href=3D"mailto:= >> >alexander.v.rabtchevich@gmx.net">alexander.v.rabtchevich@gmx.net> >> wr= >> >ites:
>> >>When you look at an imported image in darktable without applying >> any> >> >> >>corrections, the program shows you the embedded preview, which was >> made= >> >
>> >>by the camera itself with all the corrections it (the camera) would >> mad= >> >e
>> >>with the original RAW when converting it to jpg. If you applyin UFRaw >> a= >> >
>> >>camera curve, similar to the one in darktable, you will see the >> similar= >> >
>> >>result...
>> >It's true that the lion image imported into UFRaw is terribly over >> expo= >> >sed,
>> >but that is something that UFRaw is doing to the raw data. =A0The >> original> >br> >> >image has proper exposure which was confirmed at the time the picture >> was> >r> >> >shot as well as the proper exposure from the companion JPEG image (I >> shoot> >br> >> >RAW+JPG). =A0In UFRaw the histogram is shoved completely to the right >> edge> >br> >> >of the spectrum and there is no way to use this tool to fix the picture >> as> >br> >> >most of the image detail is already lost. =A0When I open the same file in >> t= >> >he
>> >DiMAGE Image Viewer software from Minolta (on a Windows XP machine), >> the> >> >> >raw image looks just fine and can be tweaked.
>> >So I have to assume that this is a serious bug in UFRaw and I have >> reported= >> >
>> >it as such. =A0I'm just confused that I have not heard other people >> com= >> >plaining
>> >about this problem.
>> >Regards,
>> >Jeff
>> >List address: =A0 =A0gimp-user-= >> >list@gnome.org
>> >List membership: >> https://mail.gnome.org/mailman/listinfo/gimp-use= >> >r-list
>> >List archives: =A0 https://mail.gnome.org/archives/gimp-user-list >>
>> >> >--001a11c2ef8064e2f704f65119ee-- >> >> _______________________________________________ >> gimp-user-list mailing list >> List address: gimp-user-list@gnome.org >> List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list >> List archives: https://mail.gnome.org/archives/gimp-user-list >> >--089e01493f10fa279504f651fc6e >Content-Type: text/html; charset=ISO-8859-1 >Content-Transfer-Encoding: quoted-printable >
Can you also put the jpg you shot since that tells me what= > you are expecting to see?=A0
As an aside you may want t= >o visit Dave Coffin's page and read the FAQ especially about gamma and = >linearity.
Thanks,
Partha
On Sat, Apr 5, 20= >14 at 4:11 PM, Jeffery Small <jeff@cjsa.com> wrote:
Partha Bagchi <"mailto:partha1b@gmail.com">partha1b@gmail.com> writes:
Sure. =A0Let's use the clouds photo since it is a more modern Son= >y format and
>pretty dramatically shows the loss of information. =A0Point your browser he= >re:
>and save the image. =A0This is a 24-Mb image file taken with an Alpha a77r> >camera.
>Thanks for looking at this. =A0Let me know if I can provide any additionalbr> >info.
>Regards,
>Jeff
>>On Sat, Apr 5, 2014 at 3:11 PM, Jeffery Small <jeff@cjsa.com> wrote:
>> Alexander Rabtchevich <alexander.v.rabtchevich@gmx.net= >> writes:
>>> >When you look at an imported image in darktable without applyi= >ng any
>>> >corrections, the program shows you the embedded preview, which= > was made
>>> >by the camera itself with all the corrections it (the camera) = >would made
>>> >with the original RAW when converting it to jpg. If you applyi= >n UFRaw a
>>> >camera curve, similar to the one in darktable, you will see th= >e similar
>>> >result...
>>> It's true that the lion image imported into UFRaw is terribly = >over exposed,
>>> but that is something that UFRaw is doing to the raw data. =A0The = >original
>>> image has proper exposure which was confirmed at the time the pict= >ure was
>>> shot as well as the proper exposure from the companion JPEG image = >(I shoot
>>> RAW+JPG). =A0In UFRaw the histogram is shoved completely to the ri= >ght edge
>>> of the spectrum and there is no way to use this tool to fix the pi= >cture as
>>> most of the image detail is already lost. =A0When I open the same = >file in the
>>> DiMAGE Image Viewer software from Minolta (on a Windows XP machine= >), the
>>> So I have to assume that this is a serious bug in UFRaw and I have= > reported
>>> it as such. =A0I'm just confused that I have not heard other p= >eople
>>> complaining
>>> about this problem.
>>> Regards,
>>> Jeff
>>> List address: =A0 =A0g= >imp-user-list@gnome.org
>>> List membership: https://mail.gnome.org/mailman/listinfo= >/gimp-user-list
>>> List archives: =A0 https://mail.gnome.org/archives/gimp-user-lis= >t
>>Content-Type: text/html; charset=3DISO-8859-1
>><div dir=3D3D"ltr">Can you provide an example image to = >confirm this?<div><br>=3D
>></div><div>Thanks,</div><div>Partha</div>= ></div><div class=3D3D"gmail_extra"><=3D
>>br><br><div class=3D3D"gmail_quote">On Sat, Ap= >r 5, 2014 at 3:11 PM, Jeffery S=3D
>>mall <span dir=3D3D"ltr">&lt;<a href=3D3D"m= >ailto:jeff@cjsa.com" target=3D3D&= >quot;_blan=3D
>>k">jeff@cjsa.com</a>= >&gt;</span> wrote:<br>
>><blockquote class=3D3D"gmail_quote" style=3D3D"margin= >:0 0 0 .8ex;border-left:1p=3D
>>x #ccc solid;padding-left:1ex">Alexander Rabtchevich &lt;&l= >t;a href=3D3D"mailto:=3D
>>alexander.v.rabtchev= >ich@gmx.net">>alexander.v.rabtchevich@gmx.net</a>&gt; wr=3D
>>ites:<br>
>><br>
>>&gt;When you look at an imported image in darktable without applyin= >g any<br=3D
>>&gt;corrections, the program shows you the embedded preview, which = >was made=3D
>><br>
>>&gt;by the camera itself with all the corrections it (the camera) w= >ould mad=3D
>>e<br>
>>&gt;with the original RAW when converting it to jpg. If you applyin= > UFRaw a=3D
>><br>
>>&gt;camera curve, similar to the one in darktable, you will see the= > similar=3D
>><br>
>>&gt;result...<br>
>><br>
>>It&#39;s true that the lion image imported into UFRaw is terribly o= >ver expo=3D
>>sed,<br>
>>but that is something that UFRaw is doing to the raw data. =3DA0The ori= >ginal<=3D
>>br>
>>image has proper exposure which was confirmed at the time the picture w= >as<b=3D
>>r>
>>shot as well as the proper exposure from the companion JPEG image (I sh= >oot<=3D
>>br>
>>RAW+JPG). =3DA0In UFRaw the histogram is shoved completely to the right= > edge<=3D
>>br>
>>of the spectrum and there is no way to use this tool to fix the picture= > as<=3D
>>br>
>>most of the image detail is already lost. =3DA0When I open the same fil= >e in t=3D
>>he<br>
>>DiMAGE Image Viewer software from Minolta (on a Windows XP machine), th= >e<br=3D
>>raw image looks just fine and can be tweaked.<br>
>><br>
>>So I have to assume that this is a serious bug in UFRaw and I have repo= >rted=3D
>><br>
>>it as such. =3DA0I&#39;m just confused that I have not heard other = >people com=3D
>>plaining<br>
>>about this problem.<br>
>><br>
>>Regards,<br>
>>--<br>
>>Jeff<br>
>><br>
>>_______________________________________________<br>
>>gimp-user-list mailing list<br>
>>List address: =3DA0 =3DA0<a href=3D3D"mailto:gimp-user-list@gnome.org">gimp-user-= >=3D
>>list@gnome.org</a><br>= >;
>>List membership: <a href=3D3D"https://mail.gnome.org/mail= >man/listinfo/gimp-us=3D
>>er-list" target=3D3D"_blank">https://mail.gnom= >e.org/mailman/listinfo/gimp-use=3D
>>r-list</a><br>
>>List archives: =3DA0 <a href=3D3D"https://mail.gnome.org/ar= >chives/gimp-user-lis=3D
>>t" target=3D3D"_blank">https://mail.gnome.org/archi= >ves/gimp-user-list</a><br>
>></blockquote></div><br></div>
>List address: =A0 =A0gimp-user-= >list@gnome.org
>List membership: https://mail.gnome.org/mailman/listinfo/gimp-use= >r-list
>--089e01493f10fa279504f651fc6e--
Partha Bagchi
2014-04-06 03:08:51 UTC (about 11 years ago)
I admit I missed your previous image and so apologies I don't know what Darktable shows.
When I processed in UFRaw (version 0.20, my build and part of my Gimp build for Windows 64-bit), It looks fine. I set the exposure to -1.48, White-balance to Daylight.
If I play a little more with the curves, I get results similar to Photoshop CC with ACR 8.3. So, I don't think you are missing anything.
I did process in Gimp 2.9 with UFRaw 16-bit.
Hope that helps.
Partha
Regards, --
Jeff
and
Jeff
made
made
UFRaw a
similar
result...
exposed,
original
was
shoot
edge
as
in
the
the
reported
about this problem.
Jeff
List address: gimp-user-list@gnome.org List membership:
this?=
Thanks,Partha
Jeffery
S=
mall <
target=3D"_blan=
margin:0 0 0
href=3D"mailto:=
wr=
ites:
any
made=
mad=
e
UFRaw
a=
similar=
>result...
expo=
sed,
original
br>
was
r>
shoot
br>
edge
br>
as
br>
in
t=
he
the
reported=
com=
plaining
about this problem.
Jeff
">gimp-user-=
list@gnome.org
List membership:
r-list
List archives: =A0
what=
you are expecting to see?=A0As an aside you may want
t=
and =
linearity.
20=
14 at 4:11 PM, Jeffery Small <mailto:
jeff@c=
jsa.com" target=3D"_blank">jeff@cjsa.com> wrote: margin:0 0 0
x #ccc solid;padding-left:1ex">Partha Bagchi <
href=3D=
Son=
y format and
he=
re:
target=3D"=
_blank">http://smallthoughts.com/photos/misc/GIMP/clouds.arw
a77
r>
camera.
additional
br>
info.
Jeff
>On Sat, Apr 5, 2014 at 3:11 PM, Jeffery Small <mailto:
jef=
href=3D"=
mailto:alexander.v.rabtchevich@gmx.net">alexander.v.rabtchevich@gmx.net
> writes:
applyi=
ng any
which=
was made
camera) =
would made
applyi=
n UFRaw a
th=
e similar
>> >result...
terribly =
over exposed,
=A0The =
original
pict=
ure was
image =
(I shoot
ri=
ght edge
pi=
cture as
same =
file in the
machine=
), the
>> raw image looks just fine and can be tweaked. >>
have=
reported
p=
eople
>> complaining
>> about this problem.
>> Regards,
>> Jeff
>> _______________________________________________ >> gimp-user-list mailing list >> List address: =A0 =A0mailto:gimp-user-list@gnome.org
">g=
>> List membership:
https://mail.gnome.org/mailman/listinf=
o/gimp-user-list" target=3D"_blank">
/gimp-user-list
>> List archives: =A0
https://mail.gnome.org/archives/gimp=
t
>--001a11c2ef8064e2f704f65119ee >Content-Type: text/html; charset=3DISO-8859-1 >Content-Transfer-Encoding: quoted-printable
to =
></div><div>Thanks,</div><div>Partha</div>= </div><div class=3D3D"gmail_extra"><=3D >br><br><div class=3D3D"gmail_quote">On Sat,
Ap=
r 5, 2014 at 3:11 PM, Jeffery S=3D >mall <span dir=3D3D"ltr">&lt;<a
href=3D3D"m=
target=3D3D&=
quot;_blan=3D
>k">jeff@cjsa.com
</a>=
&gt;</span> wrote:<br> ><blockquote class=3D3D"gmail_quote"
style=3D3D"margin=
&lt;&l=
">alexander.v.rabtchev=
ich@gmx.net">mailto:
alexander.v.rabtchevich@gmx.net"=
>ites:<br>
><br> >&gt;When you look at an imported image in darktable without
applyin=
g any<br=3D
which =
was made=3D
><br>
w=
ould mad=3D
>e<br>
applyin=
UFRaw a=3D
><br>
the=
similar=3D
><br>
>&gt;result...<br>
><br>
o=
ver expo=3D
>sed,<br>
ori=
ginal<=3D
>br>
w=
as<b=3D
>r>
sh=
oot<=3D
>br>
right=
edge<=3D
>br>
picture=
as<=3D
>br>
fil=
e in t=3D
>he<br>
th=
e<br=3D
>raw image looks just fine and can be tweaked.<br> ><br>
repo=
rted=3D
><br>
other =
people com=3D
>plaining<br>
><br>
>Regards,<br>
>--<br>
>Jeff<br>
><br>
>_______________________________________________<br> >gimp-user-list mailing list<br> >List address: =3DA0 =3DA0<a href=3D3D"mailto:
href=3D"mailto:=
gimp-user-list@gnome.org">gimp-user-list@gnome.org
">gimp-user-=
=3D
>list@gnome.org
</a><br>=
https://mail.gnome.org=
/mailman/listinfo/gimp-us=3D" target=3D"_blank">
https://mail.=
gnome.org/mailman/listinfo/gimp-use=3D" target=3D"_blank">
https://mail.gnom=
e.org/mailman/listinfo/gimp-use=3D >r-list</a><br>
https://mail.gnome=
.org/archives/gimp-user-lis=3D" target=3D"_blank">
https://mail.gnome.=
org/archives/gimp-user-list" target=3D"_blank">
ves/gimp-user-list</a><br> ></blockquote></div><br></div>
">gimp-user-=
list@gnome.org
List membership:
r-list
List archives: =A0
