Gimp Java Batch not working
Gimp Java Batch not working Andreas Truszkowski 07 Mar 09:52
  Gimp Java Batch not working Andreas Truszkowski 07 Mar 09:54
   Gimp Java Batch not working Ofnuts 07 Mar 20:58
  Gimp Java Batch not working Kevin Payne 07 Mar 10:19
  Gimp Java Batch not working Kevin Cozens 07 Mar 16:30
Andreas Truszkowski
2014-03-07 09:52:27 UTC (about 11 years ago)
Hi there,
I am new to Gimp and first I want to thank the Gimp community for such a great application.
But here is my problem. I try to process images from within a Java application. When I run the assembled batch command the gimp console writes that the execution was successfull.
But actually nothing happens. Here is my Java code:
The resulting command line is:
"C:\Program Files\GIMP 2\bin\gimp-2.8.exe" -i -b '(let* ((image (car (gimp-file-load RUN-NONINTERACTIVE
"z:\test\26cf5abe-eaa1-4ddd-af04-3d9e59804ed2.png" "z:\test\26cf5abe-eaa1-4ddd-af04-3d9e59804ed2.png")))(drawable (car (gimp-image-get-active-layer image))))(plug-in-sobel RUN-NONINTERACTIVE image drawable 1 1 1)(gimp-file-save RUN-NONINTERACTIVE image drawable "z:\test\test.png" "z:\test\test.png")(gimp-image-delete image))' -b '(gimp-quit 0)'
Executing this directly from command line does not fix the problem. Anyone a clue what I make wrong? Thank you in advance...
Kind regards, Andreas
Andreas Truszkowski
2014-03-07 09:54:27 UTC (about 11 years ago)
... the Java code :) :
File imageFile = new File(this.targetDir.getPath() + File.separator + UUID.randomUUID().toString() + ".png"); File testFile = new File(this.targetDir.getPath() + File.separator + "test.png");
Tools.compressJpegFile(imageFile, inImage, 1.0f); String argString = String.format("(let* ((image (car (gimp-file-load RUN-NONINTERACTIVE \"%s\" \"%s\")))" + "(drawable (car (gimp-image-get-active-layer image))))" + "(plug-in-sobel RUN-NONINTERACTIVE image drawable 1 1 1)" + "(gimp-file-save RUN-NONINTERACTIVE image drawable \"%s\" \"%s\")"
+ "(gimp-image-delete image))", imageFile.getPath(), imageFile.getPath(), testFile.getPath(), testFile.getPath()); String script = String.format("\"C:\\Program Files\\GIMP 2\\bin\\gimp-2.8.exe\" -i -b '%s' -b '(gimp-quit 0)'", argString); ProcessBuilder builder = new ProcessBuilder(script); builder.directory(this.targetDir); builder.redirectErrorStream(true); if (!this.isCancelled()) {
Process process = builder.start(); InputStream is = process.getInputStream(); InputStreamReader isr = new InputStreamReader(is); BufferedReader br = new BufferedReader(isr); String line;
while ((line = br.readLine()) != null) { System.out.println(line); }
System.out.println("Program terminated!"); process.waitFor();
Kind regards,
Andreas
Am 07.03.2014 10:52, schrieb Andreas Truszkowski:
Hi there,
Kevin Payne
2014-03-07 10:19:07 UTC (about 11 years ago)
Try replacing the single quote marks ' with double quotes " and also escaping the escaping the existing double quotes inside the single quotes:
"C:\Program Files\GIMP 2\bin\gimp-2.8.exe" -i -b "(let* ((image (car (gimp-file-load RUN-NONINTERACTIVE \"z:\test\26cf5abe-eaa1-4ddd-af04-3d9e59804ed2.png\" ...
I'm not sure if you will also have to escape the backslashes in file name paths as well: \"z:\\test\\26cf5abe-eaa1-4ddd-af04-3d9e59804ed2.png\"
Kevin
Date: Fri, 7 Mar 2014 10:52:27 +0100 From: at_lists@gmx.de
To: gimp-user-list@gnome.org
Subject: [Gimp-user] Gimp Java Batch not working
Hi there,
Kevin Cozens
2014-03-07 16:30:32 UTC (about 11 years ago)
[snip]
The Scheme code looks correct, AFAICT. If in doubt, paste the code in to the Script-Fu console and see if it works as expected or if it spits out error messages.
If you run that code from a Windows command line you have to be aware of whether the \ characters are being seen as \ or if they are being used to escape the following character.
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
2014-03-07 20:58:21 UTC (about 11 years ago)
Kind regards,
Andreas
Hi there,
You should really use the |*ProcessBuilder *(List
> command)
contructor, that will give you more control on the parameters and let you avoid a lot of quoting and escaping. And instead of calling Gimp, make it call a small script/program that dumps its parameters to stdout. As far as I can tell you are using the Unix shell syntax (leading single quote) while the file names indicate you are on Windows...
You will also save you a lot of grief by making all your scheme code a small script. Once that works you can try to pack the whole script back in a parameter.
If you call gimp with -c you will get messages printed to the console (ie, stdout) instead of being displayed by the graphical UI
