Shorcuts for layer blending modes
Shorcuts for layer blending modes Cédric GEMY 02 Sep 18:06
  Shorcuts for layer blending modes Sven Neumann 02 Sep 21:44
   Shorcuts for layer blending modes Alan Horkan 03 Sep 22:54
Cédric GEMY
2004-09-02 18:06:44 UTC (over 20 years ago)
It seems that shortcuts can be customized only for menuitems. Is there any issue to attribute one to controls (for example, layers blending modes) ?
Cedric
2004-09-02 21:44:45 UTC (over 20 years ago)
Cédric GEMY writes:
Yes, it isn't possible to assign shortcuts to items in GtkOptionMenus or GtkComboBoxes.
There's a patch in Bugzilla however that will most likely get into GIMP 2.2 that will make it possible to assign keyboard shortcuts to "Previous Layer Mode", "Next Layer Mode".
Alan Horkan
2004-09-03 22:54:23 UTC (over 20 years ago)
On Thu, 2 Sep 2004, Sven Neumann wrote:
Date: 02 Sep 2004 21:44:45 +0200
To: cedric@le-radar.com
Cc: gimp-user@lists.xcf.berkeley.edu Subject: Re: [Gimp-user] Shorcuts for layer blending modes
Cédric GEMY writes:
I dont know if it is the current behaviour is intended or not but would it be possible to change the drop down widget in the Layer dialog to hold focus, so that when you press up or down rather moving to the next widget you would instead switch to the next mode in the list?
Other keyboard shortcuts for changing mode would still be useful as they would save users switching to the context of the Layer dialog. My suggestion is similar but seperate.
- Alan
