Correcting "grainy" resolution?
Correcting "grainy" resolution? pfaoro 24 Jan 19:24
  Correcting "grainy" resolution? john Culleton 26 Jan 15:00
   Correcting "grainy" resolution? pfaoro 26 Jan 20:03
  Correcting "grainy" resolution? Liam R E Quin 26 Jan 20:50
2014-01-24 19:24:59 UTC (about 11 years ago)
Is there a (simple) way to blow up a snapshot originally take with a slow, cheap, disposable camera without having the result so grainy that it isn't usable?
john Culleton
2014-01-26 15:00:35 UTC (about 11 years ago)
You can't increase dot density in a bitmap file. Facing that problem I would import the bitmap file into Inkscape and then convert it to a vector file. Then I would blow up the vector file. You will lose some detail but at least it won't be grainy.
John Culleton
Wexford Press
Free list of books for self-publishers:
http://wexfordpress.net/shortlist.html
PDF e-book: "Create Book Covers with Scribus"
available at
http://www.booklocker.com/books/4055.html
2014-01-26 20:03:20 UTC (about 11 years ago)
Thanks; I'll do the best I can by converting to a bitmap but I'm afraid vector files and Inkscape leave me a stranger in a strange land.
Liam R E Quin
2014-01-26 20:50:29 UTC (about 11 years ago)
What I do sometimes is use a step or staircase resize - there's one in fx-foundry for example - to go twice or three times as big as I want.
Then do either gaussian blur or selective gausian blur (depends on the image) and use filters->enhance->sharpen maybe to 80% (it will look awful at this stage), then deal with (clone, erase, dodge burn) any obvious problems, then scale down using the Cubic filter, which will soften those oversharped edges...
Another approach (depends on the kind of noise in the image) is to decompose into H S V layers and blur the H layer before scaling up, as some cameras tend just to swap colours, they say. Mine doesn't.
There are more sophisticated approaches using fourier transform and wavelet decomposition, and sometimes they get better results and sometimes not.
If you want to print the photo, print at 72 or 144dpi, and use absorbent paper (not glossy or extra smooth inkjet paper for example, but writing paper), and the paper will mask a lot of the problems :D
Without seeing the picture it's hard to know, I'm afraid.
Liam
