Old Digital Photo Frame
7 of 7 messages available
Old Digital Photo Frame Paul_Clarke 12 Jan 03:29
  Old Digital Photo Frame scl 12 Jan 10:20
  Old Digital Photo Frame Ofnuts 12 Jan 13:40
   Old Digital Photo Frame Jernej Simončič 12 Jan 23:25
    Old Digital Photo Frame Paul_Clarke 13 Jan 07:31
     Old Digital Photo Frame Ofnuts 13 Jan 20:56
      Old Digital Photo Frame Paul_Clarke 14 Jan 09:07
2014-01-12 03:29:35 UTC (over 11 years ago)
Hello
I have been given a circa 2006 Photo frame that works very well except the system on it is set for DOS 16 bit and my more modern photos refuse to work.
I can save the photos but is errors on them.
How do I save the photos in a form that this device can use?
Thank you for any assistance
Regards
Paul
scl
2014-01-12 10:20:32 UTC (over 11 years ago)
On 12.1.2014 at 4:29 AM Paul_Clarke wrote:> I have been given a circa 2006 Photo frame that works very well except the
Hi Paul,
without an exact error message we can just guess. I think, following these steps will help you:
1. Look into the photo frame manual to see which image types it can handle. I guess JPEG/JPG will be among them.
2. If the images are not already in this format: open them in GIMP and export them to that format (if GIMP has it, but of course it can export to JPEG). If you have many photos to convert using GIMP will surely take a long time. You might have more luck then with image viewing or conversion programs, which can do this as batch job.
3. If that doesn't work then something else might be the cause. Try to find support from the photoframes manual, manufacturer or community.
Greetings,
2014-01-12 13:40:05 UTC (over 11 years ago)
On 01/12/2014 04:29 AM, Paul_Clarke wrote:
Hello
Regards
Paul
Old hardware (digital frames or DVD readers with a slide show function) doesn't support "progressive" JPEG while this has become a default setting in recent Gimp releases. This can be changed in the the JPEG save dialog settings (advanced options)(and save that as the new defaults...).
Jernej Simončič
2014-01-12 23:25:00 UTC (over 11 years ago)
If that's the case, existing progressive JPEGs can also be losslessly transformed to standard ones by using jpegtran inputfile.jpg > outputfile.jpg
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
2014-01-13 07:31:33 UTC (over 11 years ago)
Hello and thank you for your reply.
I'm confused. In my GIMP there is on JPG advanced save function . There is an export function but it gives you no advanced options
Regards
Paul Clarke Queanbeyan Australia
2014-01-13 20:56:37 UTC (over 11 years ago)
Regards
When you export a JPG you get this:
http://i.imgur.com/XAILJwJ.png
And when you expand the Advanced Options you get this:
http://i.imgur.com/T5gyRSr.png
2014-01-14 09:07:55 UTC (over 11 years ago)
Hello
Thank you for your reply it works a treat
Regards
Paul
