Export Quality Question
Export Quality Question wardgimp 19 Dec 13:05
  Export Quality Question wardgimp 19 Dec 13:06
   Export Quality Question Ofnuts 20 Dec 00:48
2013-12-19 13:05:35 UTC (over 11 years ago)
Hi
I'm a pretty new GIMP user. I have been working on some images for my church, for use on the web and print. In particular I have been using transparent images overlaid on other images or backgrounds. But when I export those images (in any format) the transparent elements appear 'dirty' or 'fuzzy.' As below.
Any advice or tips on how to avoid this would be appreciated!
Thanks.
2013-12-19 13:06:24 UTC (over 11 years ago)
Hi
Thanks.
2013-12-20 00:48:16 UTC (over 11 years ago)
On 12/19/2013 02:06 PM, wardgimp wrote:
Hi
Thanks.
* http://www.gimpusers.com/system/attachments/89/original/New_City_with_MK_Central.png
Do you scale down before export? All scaling (even scaling down) introduces a little blur because pixels are interpolated. This is especially true of the anti-aliasing pixels (those partially transparent pixels along the edge of your text).
