GIMP installation on Solaris
| GIMP installation on Solaris | Colin Bannister | 27 Aug 17:22 |
| GIMP installation on Solaris | Colin Bannister | 02 Sep 11:08 |
| GIMP installation on Solaris | Marc) (A.) (Lehmann | 02 Sep 13:08 |
| GIMP installation on Solaris | Karlheinz Guenster | 02 Sep 16:10 |
| GIMP installation on Solaris | Manish Singh | 02 Sep 19:15 |
| GIMP installation on Solaris | Colin Bannister | 03 Sep 11:44 |
Nicolas Khanukaev 24/07/2004 01:34:18 >>>
Hi!
Just saw your post while searching for the same compilation errors. The solution is to edit manually Xft.h
before including #include
(in xft-2.1.2 it's Xft.h, line 41) you should place a
#includeBut make sure that only freetype2 is available while compiling (at best, uninstall freetype1)
Hope it helps
Thanks a lot, Nicholas, I am making more progress now.
Colin
This message has been scanned but we cannot guarantee that it and any attachments are free from viruses or other damaging content: you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
I've got further with installation of GIMP 2 on Solaris, but have hit a problem in the Gtk installation, message included below.
Once again, is anyone using GIMP 2 on Solaris ? Any help gratefully received.
Colin
gunthorpe$ make
make all-recursive
Making all in po
Making all in po-properties
Making all in gdk-pixbuf
make all-recursive
Making all in pixops
Making all in gdk
make all-recursive
Making all in x11
Making all in gtk
make all-recursive
Making all in stock-icons
Making all in theme-bits
Making all in xdgmime
Making all in modules
Making all in input
if /bin/bash ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../../gdk -I../../gdk -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DG_DISABLE_CAST_CHECKS -threads -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/local/include/pango-1.0 -I/usr/local/include -I/usr/openwin/include -I/usr/local/include/freetype2 -I/usr/local/include/atk-1.0 -mcpu=v9 -Wall -MT gtkimcontextxim.lo -MD -MP -MF ".deps/gtkimcontextxim.Tpo" \
-c -o gtkimcontextxim.lo `test -f 'gtkimcontextxim.c' || echo './'`gtkimcontextxim.c; \
then mv -f ".deps/gtkimcontextxim.Tpo" ".deps/gtkimcontextxim.Plo"; \
else rm -f ".deps/gtkimcontextxim.Tpo"; exit 1; \
fi
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../.. -I../../gdk -I../../gdk -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DGTK_DISABLE_DEPRECATED -DG_DISABLE_CAST_CHECKS -threads -I/usr/local/include/glib-2.0 -I/usr/local/lib/glib-2.0/include -I/usr/local/include/pango-1.0 -I/usr/local/include -I/usr/openwin/include -I/usr/local/include/freetype2 -I/usr/local/include/atk-1.0 -mcpu=v9 -Wall -MT gtkimcontextxim.lo -MD -MP -MF .deps/gtkimcontextxim.Tpo -c gtkimcontextxim.c -fPIC -DPIC -o .libs/gtkimcontextxim.o
cc1: warning: changing search order for system directory "/usr/local/include"
cc1: warning: as it has already been specified as a non-system directory
In file included from ../../gdk/x11/gdkx.h:33,
from gtkimcontextxim.h:24,
from gtkimcontextxim.c:29:
/usr/openwin/include/X11/Xlib.h:32: warning: ignoring #pragma ident
In file included from ../../gdk/x11/gdkx.h:34,
/usr/openwin/include/X11/Xutil.h:56: warning: ignoring #pragma ident
gtkimcontextxim.c:67: parse error before "XICCallback"
gtkimcontextxim.c:67: warning: no semicolon at end of struct or union
gtkimcontextxim.c:71: parse error before ':' token
gtkimcontextxim.c:72: parse error before ':' token
gtkimcontextxim.c:73: parse error before ':' token
gtkimcontextxim.c:74: parse error before ':' token
gtkimcontextxim.c:75: parse error before ':' token
gtkimcontextxim.c: In function `gtk_im_context_xim_register_type':
gtkimcontextxim.c:166: sizeof applied to an incomplete type
gtkimcontextxim.c: In function `setup_im':
gtkimcontextxim.c:316: warning: implicit declaration of function `XSetIMValues'
gtkimcontextxim.c: In function `xim_instantiate_callback':
gtkimcontextxim.c:428: warning: passing arg 5 of `XUnregisterIMInstantiateCallback' from incompatible pointer type
gtkimcontextxim.c:428: warning: passing arg 6 of `XUnregisterIMInstantiateCallback' from incompatible pointer type
gtkimcontextxim.c: In function `xim_info_try_im':
gtkimcontextxim.c:453: warning: passing arg 5 of `XRegisterIMInstantiateCallback' from incompatible pointer type
gtkimcontextxim.c:453: warning: passing arg 6 of `XRegisterIMInstantiateCallback' from incompatible pointer type
gtkimcontextxim.c: In function `gtk_im_context_xim_init':
gtkimcontextxim.c:554: dereferencing pointer to incomplete type
gtkimcontextxim.c:555: dereferencing pointer to incomplete type
gtkimcontextxim.c:556: dereferencing pointer to incomplete type
gtkimcontextxim.c:557: dereferencing pointer to incomplete type
gtkimcontextxim.c:558: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_finalize':
gtkimcontextxim.c:566: dereferencing pointer to incomplete type
gtkimcontextxim.c:570: dereferencing pointer to incomplete type
gtkimcontextxim.c:571: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `reinitialize_ic':
gtkimcontextxim.c:579: dereferencing pointer to incomplete type
gtkimcontextxim.c:581: dereferencing pointer to incomplete type
gtkimcontextxim.c:582: dereferencing pointer to incomplete type
gtkimcontextxim.c:585: dereferencing pointer to incomplete type
gtkimcontextxim.c:587: dereferencing pointer to incomplete type
gtkimcontextxim.c:588: dereferencing pointer to incomplete type
gtkimcontextxim.c:596: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `set_ic_client_window':
gtkimcontextxim.c:604: dereferencing pointer to incomplete type
gtkimcontextxim.c:606: dereferencing pointer to incomplete type
gtkimcontextxim.c:607: dereferencing pointer to incomplete type
gtkimcontextxim.c:610: dereferencing pointer to incomplete type
gtkimcontextxim.c:612: dereferencing pointer to incomplete type
gtkimcontextxim.c:614: dereferencing pointer to incomplete type
gtkimcontextxim.c:615: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_new':
gtkimcontextxim.c:638: dereferencing pointer to incomplete type
gtkimcontextxim.c:641: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `mb_to_utf8':
gtkimcontextxim.c:653: dereferencing pointer to incomplete type
gtkimcontextxim.c:658: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_filter_keypress':
gtkimcontextxim.c:687: dereferencing pointer to incomplete type
gtkimcontextxim.c:704: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_focus_in':
gtkimcontextxim.c:762: dereferencing pointer to incomplete type
gtkimcontextxim.c:766: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_focus_out':
gtkimcontextxim.c:781: dereferencing pointer to incomplete type
gtkimcontextxim.c:785: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_set_use_preedit':
gtkimcontextxim.c:830: dereferencing pointer to incomplete type
gtkimcontextxim.c:832: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_reset':
gtkimcontextxim.c:855: dereferencing pointer to incomplete type
gtkimcontextxim.c:890: dereferencing pointer to incomplete type
gtkimcontextxim.c:892: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_get_preedit_string':
gtkimcontextxim.c:950: dereferencing pointer to incomplete type
gtkimcontextxim.c:960: dereferencing pointer to incomplete type
gtkimcontextxim.c:962: dereferencing pointer to incomplete type
gtkimcontextxim.c:983: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `preedit_start_callback':
gtkimcontextxim.c:994: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `preedit_done_callback':
gtkimcontextxim.c:1008: dereferencing pointer to incomplete type
gtkimcontextxim.c:1010: dereferencing pointer to incomplete type
gtkimcontextxim.c:1011: dereferencing pointer to incomplete type
gtkimcontextxim.c:1015: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `xim_text_to_utf8':
gtkimcontextxim.c:1035: dereferencing pointer to incomplete type
gtkimcontextxim.c:1041: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `preedit_draw_callback':
gtkimcontextxim.c:1087: dereferencing pointer to incomplete type
gtkimcontextxim.c:1088: dereferencing pointer to incomplete type
gtkimcontextxim.c:1090: dereferencing pointer to incomplete type
gtkimcontextxim.c:1094: dereferencing pointer to incomplete type
gtkimcontextxim.c:1104: dereferencing pointer to incomplete type
gtkimcontextxim.c:1106: dereferencing pointer to incomplete type
gtkimcontextxim.c:1108: dereferencing pointer to incomplete type
gtkimcontextxim.c:1109: dereferencing pointer to incomplete type
gtkimcontextxim.c:1110: dereferencing pointer to incomplete type
gtkimcontextxim.c:1115: dereferencing pointer to incomplete type
gtkimcontextxim.c:1117: dereferencing pointer to incomplete type
gtkimcontextxim.c:1118: dereferencing pointer to incomplete type
gtkimcontextxim.c:1123: dereferencing pointer to incomplete type
gtkimcontextxim.c:1125: dereferencing pointer to incomplete type
gtkimcontextxim.c:1126: dereferencing pointer to incomplete type
gtkimcontextxim.c:1132: dereferencing pointer to incomplete type
gtkimcontextxim.c:1133: dereferencing pointer to incomplete type
gtkimcontextxim.c:1136: dereferencing pointer to incomplete type
gtkimcontextxim.c:1141: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `preedit_caret_callback':
gtkimcontextxim.c:1155: dereferencing pointer to incomplete type
gtkimcontextxim.c:1156: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `status_draw_callback':
gtkimcontextxim.c:1194: dereferencing pointer to incomplete type
gtkimcontextxim.c:1195: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `set_preedit_callback':
gtkimcontextxim.c:1320: dereferencing pointer to incomplete type
gtkimcontextxim.c:1321: dereferencing pointer to incomplete type
gtkimcontextxim.c:1322: dereferencing pointer to incomplete type
gtkimcontextxim.c:1323: dereferencing pointer to incomplete type
gtkimcontextxim.c:1324: dereferencing pointer to incomplete type
gtkimcontextxim.c:1325: dereferencing pointer to incomplete type
gtkimcontextxim.c:1326: dereferencing pointer to incomplete type
gtkimcontextxim.c:1327: dereferencing pointer to incomplete type
gtkimcontextxim.c:1329: dereferencing pointer to incomplete type
gtkimcontextxim.c:1330: dereferencing pointer to incomplete type
gtkimcontextxim.c:1331: dereferencing pointer to incomplete type
gtkimcontextxim.c:1332: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `set_status_callback':
gtkimcontextxim.c:1339: dereferencing pointer to incomplete type
gtkimcontextxim.c:1340: dereferencing pointer to incomplete type
gtkimcontextxim.c:1341: dereferencing pointer to incomplete type
gtkimcontextxim.c:1342: dereferencing pointer to incomplete type
gtkimcontextxim.c:1343: dereferencing pointer to incomplete type
gtkimcontextxim.c:1344: dereferencing pointer to incomplete type
gtkimcontextxim.c:1347: dereferencing pointer to incomplete type
gtkimcontextxim.c:1348: dereferencing pointer to incomplete type
gtkimcontextxim.c:1349: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `set_string_conversion_callback':
gtkimcontextxim.c:1357: dereferencing pointer to incomplete type
gtkimcontextxim.c:1360: dereferencing pointer to incomplete type
gtkimcontextxim.c:1361: dereferencing pointer to incomplete type
gtkimcontextxim.c:1361: `XICProc' undeclared (first use in this function)
gtkimcontextxim.c:1361: (Each undeclared identifier is reported only once
gtkimcontextxim.c:1361: for each function it appears in.)
gtkimcontextxim.c:1361: parse error before "string_conversion_callback"
gtkimcontextxim.c:1365: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `gtk_im_context_xim_get_ic':
gtkimcontextxim.c:1372: dereferencing pointer to incomplete type
gtkimcontextxim.c:1375: dereferencing pointer to incomplete type
gtkimcontextxim.c:1384: dereferencing pointer to incomplete type
gtkimcontextxim.c:1385: dereferencing pointer to incomplete type
gtkimcontextxim.c:1391: dereferencing pointer to incomplete type
gtkimcontextxim.c:1396: dereferencing pointer to incomplete type
gtkimcontextxim.c:1410: dereferencing pointer to incomplete type
gtkimcontextxim.c:1415: dereferencing pointer to incomplete type
gtkimcontextxim.c:1417: dereferencing pointer to incomplete type
gtkimcontextxim.c:1438: dereferencing pointer to incomplete type
gtkimcontextxim.c:1442: dereferencing pointer to incomplete type
gtkimcontextxim.c:1446: dereferencing pointer to incomplete type
gtkimcontextxim.c:1449: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `disclaim_status_window':
gtkimcontextxim.c:1492: dereferencing pointer to incomplete type
gtkimcontextxim.c:1494: dereferencing pointer to incomplete type
gtkimcontextxim.c:1496: dereferencing pointer to incomplete type
gtkimcontextxim.c:1498: dereferencing pointer to incomplete type
gtkimcontextxim.c:1499: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `claim_status_window':
gtkimcontextxim.c:1508: dereferencing pointer to incomplete type
gtkimcontextxim.c:1510: dereferencing pointer to incomplete type
gtkimcontextxim.c:1519: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `update_status_window':
gtkimcontextxim.c:1530: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `update_in_toplevel':
gtkimcontextxim.c:1541: dereferencing pointer to incomplete type
gtkimcontextxim.c:1543: dereferencing pointer to incomplete type
gtkimcontextxim.c:1545: dereferencing pointer to incomplete type
gtkimcontextxim.c:1548: dereferencing pointer to incomplete type
gtkimcontextxim.c:1551: dereferencing pointer to incomplete type
gtkimcontextxim.c:1552: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `update_client_widget':
gtkimcontextxim.c:1596: dereferencing pointer to incomplete type
gtkimcontextxim.c:1598: dereferencing pointer to incomplete type
gtkimcontextxim.c:1600: dereferencing pointer to incomplete type
gtkimcontextxim.c:1604: dereferencing pointer to incomplete type
gtkimcontextxim.c:1606: dereferencing pointer to incomplete type
gtkimcontextxim.c:1607: dereferencing pointer to incomplete type
gtkimcontextxim.c:1611: dereferencing pointer to incomplete type
gtkimcontextxim.c: In function `status_window_free':
gtkimcontextxim.c:1679: dereferencing pointer to incomplete type
gtkimcontextxim.c: At top level:
gtkimcontextxim.c:1205: warning: `string_conversion_callback' defined but not used
*** Error code 1
make: Fatal error: Command failed for target `gtkimcontextxim.lo'
Current working directory /work/cczcb/gtk+-2.4.1/modules/input
*** Error code 1
make: Fatal error: Command failed for target `all-recursive'
*** Error code 1
*** Error code 1
make: Fatal error: Command failed for target `all'
Dr. Colin Bannister
Information Services
Cripps Computing Centre
Tel: 0115 9513326
Fax: 0115 9513358
www: www.nottingham.ac.uk/~cczcb/
e-mail: colin.bannister@nottingham.ac.uk
I have no idea :)
However, regarding this problem:
The X11 headers on solaris specify the wrong prototype for XIMCallbacks and XICCallbacks. Working around that issue is somewhat ugly.
It's quite possible that gtk+ doesn't have such workarounds in place (after all, it's the solaris header files which are broken).
You might try using the X11 header files from xfree86 or x.org, they should work. You can also look around on google, as this is a common problem on solaris.
It could of course be sth. else, but this has bitten me a number of times when adding x input support to applications.
Hello Colin,
Look here: http://www.blastwave.org/
Greetings Karlheinz
This has been addressed since GTK+ 2.4.2. The latest is 2.4.9. It's a very good idea to use the latest version of things, unless you have a very very good reason not to.
-Yosh
Manish,
Thanks for the information. I agree using latest version is usually better, my excuse is that when I started trying this build, 2.4.1 WAS the latest version!
I will now download new version, and try that.
Colin
Manish Singh 02/09/2004 18:15:10 >>>
-Yosh
