GIMP 2 Problem
GIMP 2 Problem Johan J W Bezuidenhoud 01 Nov 14:47
  GIMP 2 Problem Ofnuts 02 Nov 11:56
  GIMP 2 Problem scl 02 Nov 12:13
2013-11-01 14:47:58 UTC (over 11 years ago)
GIMP 2 Problem
Hi out there !!!
I do hope someone can be of assistance.
I have downloaded and installed GIMP 2.8 on my desktop machine. When I click the icon the blue frame of the GIMP start-up window momentarily appears and then disappears.
Nothing else then happens - no error message nor any form of a message appears!
My desktop system runs on Windows XP SP3, with all the latest updates, etc. installed.
The anti-virus software currently installed - Windows Security Essentials. I uninstalled the anti-virus program totally, re-installed GIMP 2.8, to no avail.
My Laptop computer runs with Windows 7 (64 bit). I downloaded and installed GIMP 2.8 - it is running perfectly!!
What can possibly cause this anomaly?? Where do I begin???
Regards to all.
Johan J W Bezuidenhoud South Africa
solusys@mweb.co.za
2013-11-02 11:56:51 UTC (over 11 years ago)
GIMP 2 Problem
On 11/01/2013 03:47 PM, Johan J W Bezuidenhoud wrote:
Hi out there !!!
Regards to all.
Not too familiair with the current Windows versions but IIR there is a "gimp-console.exe" that can be use to start Gimp in a command prompt and lets you check for error messages (also IIRC, this version is meant for batch processing, it doesn't create windows)
scl
2013-11-02 12:13:08 UTC (over 11 years ago)
GIMP 2 Problem
Without further information I have no clue what causes this anomaly on your Windows XP computer and I've never faced such problems on Windows XP myself.
Please post the output of 'gimp --verbose' and then let's see. You find a short howto in the [GIMP developer wiki]. If the output is more than ca. 10 KB, please post the output somewhere else and add a link here.
What color depth does your graphics card use?
Could it also be another case of [bug 692882]?
Kind regards,
[GIMP developer wiki] http://wiki.gimp.org/index.php/Users:Tips#Getting_and_posting_the_output_of_gimp_--verbose
[bug 692882]: https://bugzilla.gnome.org/show_bug.cgi?id=692882
