Gimp 2.8 Brushes Not Working
Gimp 2.8 Brushes Not Working VGus 24 Oct 03:44
  Gimp 2.8 Brushes Not Working Alexandre Prokoudine 24 Oct 08:33
   Gimp 2.8 Brushes Not Working VGus 24 Oct 17:31
2013-10-24 03:44:23 UTC (over 11 years ago)
So I've finally upgraded to GIMP 2.8, finding that .abr was native. I've downloaded thousands of brushes, only a hundred work, MAYBE. I'm confused because even the brushes that are not in .abr form do not work. Also, sometimes if I try to fix the brushes by uninstalling and reinstalling there will be random ones that work and then old ones disappear?
2013-10-24 08:33:20 UTC (over 11 years ago)
ABR isn't native. It's Photoshop's file format, and not all revisions of that file format are supported.
Also, I don't understand this part: "even the brushes that are not in .abr form do not work". That makes no sense :) If you download some arbitrary file, why would it work? If those were GIMP's GBR brushes, that would be an entirely different thing, of course, but you didn't provide a clue :)
So, I'm afraid, you will need to elaborate a bit on the files you are talking about.
Alexandre
2013-10-24 17:31:44 UTC (over 11 years ago)
Alexandre
oh I'm sorry, I read that wrong somewhere. Okay, NOT native. I'm not sure what format they are in but it's the brush that you can see, I believe it is jpg or png. Typically the brushes I use that I'm not sure are in .abr format are just a white page in the brushes. However, the ones that worked on 2.6 for me, are the brushes that you can see the image. I've attached a link to show you what I meant, I hope it helps.
