Gimp not working with Tablet
Gimp not working with Tablet Monica Thomson 20 Oct 20:53
  Gimp not working with Tablet Thomas Taylor 22 Oct 06:55
   Gimp not working with Tablet Alexandre Prokoudine 22 Oct 18:40
    Gimp not working with Tablet Dominik Tabisz 23 Oct 00:33
   Gimp not working with Tablet Jernej Simončič 23 Oct 07:35
Monica Thomson
2013-10-20 20:53:40 UTC (over 11 years ago)
Recently got a new computer, and one of the first things I did was to upload the latest GIMP. My Wacom Bamboo Pen tablet doesn't work completely with it. EVERYTHING worked perfectly on my old computer (Windows 7, Gimp 2.6, same tablet). I currently have Windows 8, Gimp 2.8, same tablet. After removing 2.8 at one point, I tried 2.6 again...hoping it would work then...nope. I've also downloaded the most recent tablet driver from Wacom...still nothing. What happens is that the program opens and I'm able to actually move the pen around the tablet and have the mouse and clicking options. I'm able to "paint". BUT...I'm not able to change pressure settings, which is highly important for what I need. I've gone through the all of the forums I could find on this. Most say to go through Edit; Preferences; Input Devices, and make sure that the tablet is selected. It doesn't even show up there. I'm just about at my wit's end now....and I NEED to get some commissions done. -Monica
Thomas Taylor
2013-10-22 06:55:20 UTC (over 11 years ago)
On Sun, 20 Oct 2013 13:53:40 -0700 (PDT) Monica Thomson wrote:
Recently got a new computer, and one of the first things I did was to upload the latest GIMP. My Wacom Bamboo Pen tablet doesn't work completely with it. EVERYTHING worked perfectly on my old computer (Windows 7, Gimp 2.6, same tablet). I currently have Windows 8, Gimp 2.8, same tablet. After removing 2.8 at one point, I tried 2.6 again...hoping it would work then...nope. I've also downloaded the most recent tablet driver from Wacom...still nothing. What happens is that the program opens and I'm able to actually move the pen around the tablet and have the mouse and clicking options. I'm able to "paint". BUT...I'm not able to change pressure settings, which is highly important for what I need. I've gone through the all of the forums I could find on this. Most say to go through Edit; Preferences; Input Devices, and make sure that the tablet is selected. It doesn't even show up there. I'm just about at my wit's end now....and I NEED to get some commissions done. -Monica _______________________________________________ gimp-user-list mailing list List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Hi Monica,
Microsoft did a complete re-write of the code base between win 7 and win 8. Also be aware that windows support for anything not the "latest and greatest" has some serious flaws. Apple OSX and Linux have extensive support for older hardware (and usually software). For some reason MS seems to think that the code has to change every 2-5 years instead of just adding/improving things. That's why one must buy newer versions of software programs to be "compatible" with the new version of MS.
Tom
Every man is encompassed by a cloud of comforting convictions, which move with
him like flies on a summer day.
  -  Bertrand Russell
Tom Taylor - retired penguin - KG7CFC
AMD Phenom II x4 955 -- 4GB RAM -- 2x1.5TB sata2
openSUSE 13.1_RC1-x86_64
KDE 4.11.12, FF 24.0, claws-mail 3.9.2
registered linux user 263467
2013-10-22 18:40:16 UTC (over 11 years ago)
Hi Monica,
Tom,
GIMP 2.8 relies on a newer version of GTK+ where advanced input devices support on Windows is broken beyond repair.
If painting is crucial, the recommendation is to install GIMP 2.6 and use it until the port to GTK+3 is done.
Alexandre
Dominik Tabisz
2013-10-23 00:33:45 UTC (over 11 years ago)
How about workaround by virtualbox? 1) install virtualbox
2) get any os that work with Gimp 2. 8 and Your tablet(smaller is better) 3) install & run Gimp in this virtualised OS Sometimes it work, though it's usually easier to migrate to Linux (my workaround is intended for PC that can't safely run Linux)
Good luck Dominik Tabisz
P.s from android (not so)smartphone it's hard to give link, but look for "virtualboxes" - they are prepaired os images - just copy them to virtualbox and all You have to do is install Gimp On Oct 22, 2013 8:40 PM, "Alexandre Prokoudine" < alexandre.prokoudine@gmail.com> wrote:
upload
with it.
same
removing
I've
nothing.
the pen
could
and
I'm
done.
-Monica
Hi Monica,
8.
greatest"
older
the
things.
"compatible"
Tom,
Alexandre _______________________________________________ gimp-user-list mailing list
Jernej Simončič
2013-10-23 07:35:32 UTC (over 11 years ago)
This is actually completely false. Microsoft goes above and beyond to make sure old software still works on their newer OSes. Much of the bloat in Windows is there due to all the compatibility hacks they have to maintain to ensure old software doesn't break.
Tablet support in GIMP doesn't work because it's broken in Windows GTK+ port after 2.16 - this is the reason GIMP 2.6 on Windows never moved beyond GTK+ 2.16, but with 2.8 a newer version was required, which unfortunately brought tablet breakage.
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
