English (UK) help installed to unrecognised location
English (UK) help installed to unrecognised location Mark Bourne 20 Oct 20:40
  English (UK) help installed to unrecognised location Bob Long 20 Oct 21:03
  English (UK) help installed to unrecognised location Jernej Simončič 20 Oct 22:35
   English (UK) help installed to unrecognised location Mark Bourne 21 Oct 20:15
Mark Bourne
2013-10-20 20:40:23 UTC (almost 12 years ago)
I've just installed GIMP 2.8.6 and the English (United Kingdom) user manual from:
http://www.gimp.org/downloads/
on Windows Vista.
Initially, the local help was not working, and Edit > Preferences > Help System indicated "The user manual is not installed locally". After a bit of searching, I tried renaming the folder: C:\Program Files\GIMP 2\share\gimp\2.0\help\en_GB\ to:
C:\Program Files\GIMP 2\share\gimp\2.0\help\en\ and the local user manual started working as expected.
It appears the UK English help installs to a folder (en_GB) not recognised by GIMP. Not sure if this affects other operating systems as well, or just Windows.
I was about to file a bug report as I couldn't see one already, but bugzilla.gnome.org seems to have stopped responding. Will try again later, but anyway thought others might like to know the workaround.
Mark.
Bob Long
2013-10-20 21:03:37 UTC (almost 12 years ago)
Mark Bourne wrote,
on Windows Vista.
What does your Preferences|Interface|Language say?
Setting it to "English [en_GB]" may have avoided the directory rename.
Bob Long
Jernej Simončič
2013-10-20 22:35:35 UTC (almost 12 years ago)
No, if you wish that GIMP would recognize UK English help file, you have to set the interface language to UK English.
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
Mark Bourne
2013-10-21 20:15:47 UTC (almost 12 years ago)
Ah... that does make a lot of sense! The interface language is set to "System Language", which for me is English UK. However, the only other option is "English [en_US]", so guess I need to re-run the installer and include the translations - I'd deselected them to save installing a load of languages I don't need (or at least didn't think I needed...)
Thanks, Mark.
