Softproof with GIMP
Softproof with GIMP wonderer 29 Sep 17:25
  Softproof with GIMP Alexandre Prokoudine 04 Oct 13:55
wonderer
2013-09-29 17:25:47 UTC (over 11 years ago)
Softproof with GIMP
Hello there,
I want to do some softproofing and I struggle with some details. I have the Profile file (for he monitor and the printer) and it shows correctly under the Colormanagement Tab in the actual GIMP 2.8 version. Now I want to see my original Picture and the Colorcorrected e.g. for the Softproof to print side-by-side on the screen. Is there a way to get this?
Is there a way to change from "colormetric (relative)" to "colormetric (absolut) - sorry, I try to translate it from german ... - in the Colormanagement - Printsimulation Tab without doin it over the Menustructure (which takes a lot of time...)?!
Can I use CMYK im GIMP 2.8 or will it be in one of the next versions? Some literature says I have to use a Plugin Seperate+ for that.
best regards Henrik Heigl
2013-10-04 13:55:10 UTC (over 11 years ago)
Softproof with GIMP
On Sun, Sep 29, 2013 at 9:25 PM, wonderer wrote:
Hello there,
AFAIK, softproofing with separate+ plug-in creates a new image. So you can go to multiple-window mode and look at them side-by-side.
Alexandre
