integrity of distorted images
integrity of distorted images kev 25 Sep 00:29
  integrity of distorted images Ofnuts 25 Sep 12:13
   integrity of distorted images kev 25 Sep 23:09
kev
2013-09-25 00:29:11 UTC (over 11 years ago)
Hi Gimp Folk,
Just started to explore gimp. Have an application for distortion effects, but need to know the following. If I create a square (jpeg) that is exactly 50% black and 50% white and then distort the image using, for example 'i warp' or 'whirl & pinch', will the colour proportions of the resultant image still be exactly 50/50?
Hoping some tech minded person can confirm and explain this ??
Best regards
Kev Hartley
0401 206 342
No voice mail - if unanswered please call again or text.
2013-09-25 12:13:13 UTC (over 11 years ago)
On 09/25/2013 02:29 AM, kev wrote:
Hi Gimp Folk,
Why don't you try yourself? Use the Histogram dialog to check the result (I'm pretty sure the ratio is not kept)?
kev
2013-09-25 23:09:38 UTC (over 11 years ago)
G'day Ofnuts !
Thanks for the tip - you're right, according to the histogram the ratios do alter a bit but using this tool I should be able to balance them as required - you're a champ!
best lunact
Hi Gimp Folk,
Why don't you try yourself? Use the Histogram dialog to check the result (I'm pretty sure the ratio is not kept)? _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Best regards
Kev Hartley
0401 206 342
