Olympus RAW
Olympus RAW Peter Van Severen 10 Sep 19:15
  Olympus RAW A. den Oudsten 10 Sep 20:42
  Olympus RAW Patrick Shanahan 10 Sep 20:42
  Olympus RAW Kevin Cozens 10 Sep 21:35
  Olympus RAW Paul Saumane 10 Sep 23:16
Peter Van Severen
2013-09-10 19:15:34 UTC (over 11 years ago)
Olympus RAW
Was just trying to open some older pictures from my Olympus. But GIMP does not recognize the Olympus RAW-format, i.e. the ORF-extension. How to solve ?
Thanks,
Peter VS
A. den Oudsten
2013-09-10 20:42:15 UTC (over 11 years ago)
Olympus RAW
Thanks,
Peter VS _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Did you install ufraw?
Andr den Oudsten
Patrick Shanahan
2013-09-10 20:42:21 UTC (over 11 years ago)
Olympus RAW
* Peter Van Severen [09-10-13 16:24]: [...]
I am going to make some assumptions here since you were far for forthcoming and my crystal ball is in for repairs.
for linux: Install ufraw and gimp-ufraw as gimp does not natively read raw photo formats.
for other platforms, I have NO idea.
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Kevin Cozens
2013-09-10 21:35:12 UTC (over 11 years ago)
Olympus RAW
You need to install either the ufraw or dcraw plugins for GIMP. I use the dcraw plugin as I don't like how the ufraw plugin asks me about ways it could alter the image as part of the file load process.
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
Paul Saumane
2013-09-10 23:16:57 UTC (over 11 years ago)
Olympus RAW
If it is just a matter of opening them, then you can download XnView, it will open them. (I suppose that IRFANVIEW will do it too) I don't know if it can convert them into easily workable raw but you can try it ( it is converting RAW and RAWRAW) and then it will be usable with GIMP after downloading and installing UFRAW.
http://www.xnview.com/fr/index.php
note : you can select French, English and German regarding the WEB site. Your language is available as fas as the soft is concerned.
Regards
Paul
-----Message d'origine----- From: Peter Van Severen
Sent: Tuesday, September 10, 2013 9:15 PM To: gimp-user-list@gnome.org
Subject: [Gimp-user] Olympus RAW
Thanks,
Peter VS
