bit of a n00b question but...
10 of 10 messages available
bit of a n00b question but... JjStAr 02 Sep 06:10
  bit of a n00b question but... Alexandre Prokoudine 02 Sep 06:30
   bit of a n00b question but... JjStAr 02 Sep 07:12
    bit of a n00b question but... Partha Bagchi 02 Sep 18:22
     bit of a n00b question but... scl 02 Sep 20:07
    bit of a n00b question but... Jernej Simončič 02 Sep 19:16
  bit of a n00b question but... Michael Schumacher 02 Sep 18:26
   bit of a n00b question but... scl 02 Sep 20:14
  bit of a n00b question but... Gary Aitken 02 Sep 21:46
   bit of a n00b question but... JjStAr 03 Sep 00:25
2013-09-02 06:10:15 UTC (over 11 years ago)
I'm stuck. Python plugins are not installing. They don't show up. Script-Fu works fine though. Can anyone help me?
Thx in advance
JjStAr
2013-09-02 06:30:27 UTC (over 11 years ago)
Typically users make a mistake of putting Python plugins to 'scripts' folder. They should be put to plugins folder instead.
Also, please always mention your operating system when reporting issue ;-)
Alexandre
2013-09-02 07:12:47 UTC (over 11 years ago)
I'm on Mac OS X Snow Leopard 10.6.8. And I KNOW I'm putting is the Python folder.
Partha Bagchi
2013-09-02 18:22:58 UTC (over 11 years ago)
Do you see Python in the Filters menu item? It should be right above Script-Fu . If you don't then your Gimp does not support Python.
JjStAr (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
2013-09-02 18:26:40 UTC (over 11 years ago)
Are the Python files set to be executable?
chmod u+x
on a command line (I guess OS X supports this command?), and I'd assume that there is a checkbox somwhere in the UI.
Jernej Simončič
2013-09-02 19:16:56 UTC (over 11 years ago)
You should be putting them in the plug-ins folder.
< Jernej Simončič ><><><><>< http://eternallybored.org/ >
scl
2013-09-02 20:07:10 UTC (over 11 years ago)
+1
This is in particular the case if one downloaded the first OS X item on gimp.org/downloads, which is GIMP 2.8.4 without Python. Try [Partha's Mac 64-bit build] instead or - in case you have an old MacBook with only 32 bit processors - the 32 bit build for Snow Leopard from the [GIMP on OS X website].
Kind regards,
[Partha's Mac 64-bit build]: http://www.partha.com/downloads/Gimp-2.8.app.zip [GIMP on OS X website]: http://gimp.lisanet.de/Website/Download.html
scl
2013-09-02 20:14:43 UTC (over 11 years ago)
chmod u+x
Yes, that works in general on OS X.
There's a dialog in Finder for this if one right-clicks on that file and selects 'Information'.
However, one can only grant or revoke read and write permissions there, no execution permissions. That's different to Linux and Windows file managers.
Kind regards,
Gary Aitken
2013-09-02 21:46:52 UTC (over 11 years ago)
I don't know squat about Python, unfortunately. However, I just tried starting the python console on my system (freebsd) and it didn't show up.
As I was starting it from an icon on the desktop, I know from past experience that errors often get swallowed when an app is started in this manner. So I started it from a shell window and saw the related errors.
so...
Try starting the gimp from a shell window instead of the normal app launch method. Are there any errors?
Gary
2013-09-03 00:25:11 UTC (over 11 years ago)
Well... Since this is a school computer, I probably can't fix this. Thanks for the help though!
