Brush size speed
Brush size speed legna80 30 Aug 13:03
  Brush size speed Brendan Scott 30 Aug 13:34
   Brush size speed legna80 30 Aug 14:10
    Brush size speed Brendan Scott 31 Aug 02:15
2013-08-30 13:03:49 UTC (almost 12 years ago)
Brush size speed
Hi there everybody :)
Well i've, been a gimp user since quite a time now, and always loved it over photostop for doing all my work except for the one i love most, and thats digital painting. My problem is the scaling of the brushes, ive tried everthing but at the end i don't feel satisfied with the behavior of how gimp scales the brushes pixel per pixel at time, its very slow working on large canvas, i know there's the scale more shortcut but its not quite precise and swapping between the normal scale shortcut with the scale more is a pain in the ass, at least for me because i barely use the keyboard so i rely heavily on my intuos 4 medium tablet using the touch ring for scaling, so my questions are:
theres no way to have a similar brush scale behavior similar to the one in photoshop ? like it doesnt matter if im very zoomed in or very zoomed out, the brush scales fast and precise
I dont remember where i read about this other shortcut called increase brush size relative, that is like a more precise way to scale the brush size but my problem is why it does nothing after assigning a key to it ? well it does, on the bottom where zoom percentage is located,to the right ive seen that it shows the selected tool, and when i click the assigned key to the command i said before it shows Brush Angel 0.00. why? im not trying to rotate the brush im trying to scale it, maybe is a bug i dont know.
Anyways thats my issue guys, hope somebody can give me any advice for this.
By the way im on a Windows 7 ultime 64bits system. gimp 2.8.6
Sheers!
Angel
Brendan Scott
2013-08-30 13:34:11 UTC (almost 12 years ago)
Brush size speed
I usually only want one of 3 or 4 sizes. I've written a plug-in which (among other things) allows you to cycle through specific brush size presets (eg 10, 20, 40, 80) (and define your own). I have it bound to one of my side buttons.
See if it helps: http://registry.gimp.org/node/28413
2013-08-30 14:10:38 UTC (almost 12 years ago)
Brush size speed
Hey thanks for the response Brendan :)
Well its not exactly what im looking for but i ll give it a try anyways and see what happens... btw your plugin looks awesome never hear of it before :p
again thank you so much indeed!
Angel
Brendan Scott
2013-08-31 02:15:42 UTC (almost 12 years ago)
Brush size speed
On 08/31/2013 12:10 AM, legna80 wrote: []
See if it helps:
Np
Thanks - it was only released a couple of weeks ago.
Keep an eye out, I'm aiming to have a couple of improvements
