How to transform a rectangle part to triangle?
How to transform a rectangle part to triangle? Kovesdi Gyorgy 27 Aug 11:53
  How to transform a rectangle part to triangle? scl 27 Aug 17:03
   How to transform a rectangle part to triangle? Kovesdi Gyorgy 28 Aug 12:25
Kovesdi Gyorgy
2013-08-27 11:53:16 UTC (over 11 years ago)
I need to transform a rectangle part of my picture to a triangle, linearly, only with horizontal distortion, keeping vertical positions in place. (a rectangle to a triangle standing on its side, by moving the top corners to one point)
I tried the Cage Transform: the top of the picture seems good, but it also distorts the bottom line in this case. Other tools seem not suitable at all. How can I do it?
Thanx in advance Gyrgy Kvesdi
scl
2013-08-27 17:03:39 UTC (over 11 years ago)
this sounds like a clear case for the Perspective tool. You have to use Direction=Normal(Forward), in case you used the corrective (backward) direction.
Kind regards,
Kovesdi Gyorgy
2013-08-28 12:25:23 UTC (over 11 years ago)
Yes, i used normal mode: i just wanted to move the two top corners of a rectangle to get a triangle, but the bottom side is also deformed, i don't know why. I need the bottom corners to stay as is.
Regards Gyrgy Kvesdi
