Problem with the toolbox GIMP 2.8 Mac
Problem with the toolbox GIMP 2.8 Mac mauricemaurice 24 Aug 20:28
  Problem with the toolbox GIMP 2.8 Mac scl 25 Aug 07:01
   Problem with the toolbox GIMP 2.8 Mac mauricemaurice 25 Aug 10:56
    Problem with the toolbox GIMP 2.8 Mac scl 28 Aug 04:26
2013-08-24 20:28:09 UTC (over 11 years ago)
Hi everyone ! First time posting here.
I recently bought a new MacBook (Mountain Lion 10.8.4) and I decided to install GIMP, since I used it a lot on my former computer. I installed it from the website, but when I open GIMP, I have a problem with the toolbox. When I try to pick a tool, I get the tool that is 4 tools below. I don't know if I am being clear : when I try to click on "rectangular selection", for instance, it selects "compass" instead ! It works great except for that, but it is really annoying, and I cannot select the tools that are at the top op the toolbox with my mouse. I tried deleting GIMP and reinstalling it, tried both versions that are available for download, waited a few days and tried again but always the same problem.
Has any of you ever had that problem ? How can I do to get my toolbox to work normally ? Or should I try downloading an older version of GIMP ?
Thank you for reading !
scl
2013-08-25 07:01:07 UTC (over 11 years ago)
On 24.08.2013 at 10:28 P.M., mauricemaurice wrote: >
Hi mauricemaurice,
thank you for reporting this. However, at our Mac download site we have many download options for Mac users: two native builds, MacPorts and Fink. Can you please post the link you eventually used?
Thank you in advance.
Kind regards,
2013-08-25 10:56:29 UTC (over 11 years ago)
Hi ! Thank you for your quick reply !
I used thes two "native build" download links : I used http://gimp.lisanet.de/Website/Download.html first, and then ftp://ftp.gimp.org/pub/gimp/v2.8/osx/gimp-2.8.4-nopython-dmg-1.dmg and I tried each one twice (I reinstalled each one one time, after deleting).
Thank you very much ! Best regards.
scl
2013-08-28 04:26:44 UTC (over 11 years ago)
Hi mauricemaurice,
if this error happens with both versions, the cause is probably in your system. You can try the following: 1. Remove or rename the folder /Users/$username/Library/Application Support/GIMP/2.8/ (for the 2.8.4 version. For the version from gimp.lisanet.de check the location in GIMP/Preferences/Folders). Restart or reinstall GIMP.
If that doesn't work:
2. Try Partha's GIMP build: www.partha.com If that doesn't work:
3. It's perhaps a bug in OS X 10.8.4. An update to the latest 10.8.5 could perhaps fix it. The 10.8.5 version is expected to be released the next days. I don't use OS X 10.8, so take this advice without warranty, please ;-)
Kind regards,
