Blending 2 images into 1
Blending 2 images into 1 | pfaoro | 05 Aug 17:20 |
Blending 2 images into 1 | Madeleine Fisher | 05 Aug 18:05 |
Blending 2 images into 1 | Pat David | 05 Aug 18:15 |
Blending 2 images into 1 | pfaoro | 05 Aug 23:18 |
- postings
- 8
My hobby, if it can be called that, is creating comic images of individuals by combining two unrelated images into one. EXAMPLE: Placing the head of my brother-in-law on the body of Quasimodo (the Hunchback of Notre Dame).
I'm totally new with GIMP and I've figured out a good bit, such as using the magnetic lasso to copy-paste a selection from one image into another, but I can't figure out how to match skin tones and resolutions so the result appears to be a single image. At best, I can get close but not at all close enough.
Can somebody point me in the right direction, at least to identify the tools I should be using?
I'm by no means a techie, so please be gentle with me :-)
Thanks!
I think one of the first things to check out is the Colors menu on the top file bar. There are lots of options:
Color Balance (changes c, m, y in midtones, highlights, and shadows)
Hue-Saturation (you can shift around the colors in a selection)
Colorize (Makes everything different shades of a single color--can create a
sepia effect, for example)
Brightness-Contrast
Threshold (makes everything either black or white)
Levels
Curves
The last two options are REALLY useful for fine-tuned changes, but they can be kind of difficult to understand. Just play around with them and you'll get the hang of it.
Good luck!
combining two unrelated images into one. EXAMPLE: Placing the head of my brother-in-law on the body of Quasimodo (the Hunchback of Notre Dame).I'm totally new with GIMP and I've figured out a good bit, such as using the
to be a single image. At best, I can get close but not at all close enough.Can somebody point me in the right direction, at least to identify the tools I
should be using?I'm by no means a techie, so please be gentle with me :-)
Thanks!
-- pfaoro (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
This might be helpful in getting a handle on curves and blending (skin)
tones:
http://blog.patdavid.net/2012/07/getting-around-in-gimp-more-color.html
If you need an intro, there's also this: http://blog.patdavid.net/2012/06/getting-around-in-gimp-color-curves.html
Color Balance (changes c, m, y in midtones, highlights, and shadows) Hue-Saturation (you can shift around the colors in a selection) Colorize (Makes everything different shades of a single color--can create a sepia effect, for example)
Brightness-Contrast
Threshold (makes everything either black or white) Levels
CurvesThe last two options are REALLY useful for fine-tuned changes, but they can be kind of difficult to understand. Just play around with them and you'll get the hang of it.
Good luck!
combining two unrelated images into one. EXAMPLE: Placing the head ofmy
magnetic lasso to copy-paste a selection from one image into another,but
I
Thanks!
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list_______________________________________________ gimp-user-list mailing list
pat david http://blog.patdavid.net
- postings
- 8
My sincere thanks to all of you! I think I've got a handle on it now. :-)
tones:
http://blog.patdavid.net/2012/07/getting-around-in-gimp-more-color.htmlIf you need an intro, there's also this: http://blog.patdavid.net/2012/06/getting-around-in-gimp-color-curves.html
