XCF to PDF problems with font
XCF to PDF problems with font alex_g 24 Jul 16:33
  XCF to PDF problems with font Stephen Allen 25 Jul 11:51
   XCF to PDF problems with font alex_g 04 Aug 11:57
    XCF to PDF problems with font Chris Mohler 04 Aug 16:58
    XCF to PDF problems with font Stephen Allen 05 Aug 11:19
     XCF to PDF problems with font Chris Mohler 05 Aug 18:13
2013-07-24 16:33:48 UTC (over 11 years ago)
Hi there, hope somebody can help me. Am making a brochure, use the pre-set A5 print size. All great, but when converting the XCF file to PDF the fonts are not represented correct and are drastically reduced in size.
I tried the flattening option, but that takes a lot of resolution/sharpness out of the file and makes it less fit for printing... Can anybody help??
Thanks! alex
Stephen Allen
2013-07-25 11:51:24 UTC (over 11 years ago)
Thanks!
---end quoted text---
First of all, don't use the GIMP for creating a brochure. Use a page layout application. Scribus will do just nicely.
The proper tool for the job will make your life much easier. Just use GIMP for images NOT layout.
Cheers,
Stephen, Toronto
My Google+ Profile | http://goo.gl/JbQsq
2013-08-04 11:57:19 UTC (over 11 years ago)
Thanks for the tip will try it out. Scribus is a sort of Illustrator?
Thanks again and best regards Alex
Chris Mohler
2013-08-04 16:58:26 UTC (over 11 years ago)
Scribus is desktop publishing - more like InDesign than Illy.
Chris
Stephen Allen
2013-08-05 11:19:40 UTC (over 11 years ago)
No, Scribus is more like PageMaker, an earlier Adobe Page Layout Application before they introduced us to InDesign.
The open source eqivalent to Illustrator is Inkspot.
Anyway like anything; you gotta use the right tool, if one wants good results. ;)
Cheers,
Stephen, Toronto
Chris Mohler
2013-08-05 18:13:20 UTC (over 11 years ago)
I think you mean 'Inkscape' here, no?
Chris
