feature request: alpha level
feature request: alpha level Alex Vergara Gil 22 Jul 13:38
  feature request: alpha level Daniel Hornung 22 Jul 19:34
   feature request: alpha level Ofnuts 22 Jul 20:45
    feature request: alpha level Alex Vergara Gil 23 Jul 14:07
Alex Vergara Gil
2013-07-22 13:38:00 UTC (about 12 years ago)
Hello GIMP developers:
I am working on a project where I need to set all pixels below a level as alpha channel, is there a quick way to achieve this? The level can be both set a priori or adjusted dinamically, the second way is prefered. Right now my workflow includes: 1. duplicate layer.
2. use color level in duplicate layer, in menu COLOR -> LEVEL. 3. add alpha mask to original layer
4. copy duplicate layer into the alpha mask of the original. 5. delete duplicate layer.
6. If result is not ok then return to 1. As you can see this workflow is a headache, specially point 6 which is often achieved. Any thoughts
Alex
Daniel Hornung
2013-07-22 19:34:11 UTC (about 12 years ago)
I am working on a project where I need to set all pixels below a level as alpha channel, is there a quick way to achieve this? The level can be both set a priori or adjusted dinamically, the second way is prefered. Right now my workflow includes: 1. duplicate layer. 2. use color level in duplicate layer, in menu COLOR -> LEVEL. 3. add alpha mask to original layer
1. Create a channel mask from the grayscale value. 2. On the channel mask, use the threshold tool.
Voilà!
Mein öffentlicher Schlüssel / My public key: 4096R/600ACB3B 2012-04-01
Fingerabdruck / Fingerprint:
9902 575B B9A0 C339 CFDF  250B 9267 CA6B 600A CB3B
Runterladen z.B. bei/ Get it e.g. from:
pgp.mit.edu, subkeys.pgp.net, pgp.uni-mainz.de, pool.sks-keyservers.net, ...
2013-07-22 20:45:15 UTC (about 12 years ago)
Voil!
+1
For step 2) you can also uses Levels, Curves or even Brightness/Contrast, to keep some intermediate values of opacity and achieve a smoother result.
Alex Vergara Gil
2013-07-23 14:07:30 UTC (about 12 years ago)
Sent: Monday, July 22, 2013 3:45 PM
Voil!
+1
For step 2) you can also uses Levels, Curves or even Brightness/Contrast, to keep some intermediate values of opacity and achieve a smoother result. _______________________________________________
Great!
I dont know this could be done so easily. Thanks! I have adapted my workflow now.
1. Decompose original image in whatever you want RGB, LHS, LAB or even grayscale. Then pick some channel.
2. Copy the selected channel into an alpha mask of the original image. 3. Use level tool in the mask (threshold is not good because it creates sharp edges, but Curves and brightness/Contrast are good choices also).
With this workflow you can also set an alpha level on a specified channel!
Thank you all
