Fix photo with uneven exposure
Fix photo with uneven exposure billlee 20 Jul 01:57
  Fix photo with uneven exposure Owen 20 Jul 03:37
  Fix photo with uneven exposure Ofnuts 20 Jul 19:09
  Fix photo with uneven exposure devvv 21 Jul 13:14
2013-07-20 01:57:53 UTC (almost 12 years ago)
I hurriedly photographed the text in a greeting card and have uneven lighting and underexposure that I'd like to correct. Please see attachment, in which I've increased the brightness and contrast and then desaturated. This helps but it needs lots more!
I've looked at tutorials on gradient contrast masks but I get lost part way through. Either I'm too much of a newbie to understand (highly probable) or maybe the tutorials are for older versions of GIMP. (I'm on 2.8.6 for Windows.)
I am very grateful for any advice anyone would care to offer!!!
Bill
Owen
2013-07-20 03:37:57 UTC (almost 12 years ago)
needs lots more!
Use the Colors->Threshold tool
It maybe necessary to use the select tool and make various selections and then apply the threshold tool to those selections
use a brush and paint white to clean up any odd spots
See http://members.pcug.org.au/~rcook/images/threshold.png as a quicky
Owen
2013-07-20 19:09:25 UTC (almost 12 years ago)
It woud be easier for us to have the orjginal...
Many techniques I have seen stat by duplicating the image then applying a very wide gaussian blur to it, then playing with layers mode between the to images: for instance, the blurred layer on top, in "divide" mode, makes the paper uniformly white.
2013-07-21 13:14:19 UTC (almost 12 years ago)
Hi!
As already mentioned, there are several ways to correct such things. To equalize the brightness levels you could use my tutorial here: http://www.gimpusers.com/tutorials/equalize-homogenize-brightness
After that you'll get something similar to the attachment: "equalize". Apply contrast now using the levels tool (Color / Levels) and move the rectangles as seen in the image: "levels". The final result will be an image with mostly white background and well readable text.
Hope that helps!
  • First transform the background into an more even gray
  • Second get rid of the equal gray background using "Levels"
  • the contrast adjustments of the levels make the background plain white
