to save or not to save - a foolish question
to save or not to save - a foolish question Uniklaps 19 Jul 21:49
  to save or not to save - a foolish question Richard Gitschlag 20 Jul 16:06
Uniklaps
2013-07-19 21:49:14 UTC (almost 12 years ago)
Hi friends,
don't feed these trolls! See the "save as" shitstorm of June, 14th, 15th and 16th
and finish this boring debate. Whoever use GIMP just to open jpegs to look inside
his SD-card has no idea of GIMP's abilities. They better should use MS Photo editor.
Have a fine weekend!
Konrad
Richard Gitschlag
2013-07-20 16:06:54 UTC (almost 12 years ago)
I to am a bit surprised that the old topic received a new firestorm of over 50 replies in one day . . . I believe that qualifies as a "grenade" behavior.
To: gimp-user-list@gnome.org
Date: Fri, 19 Jul 2013 23:49:14 +0200 Subject: [Gimp-user] to save or not to save - a foolish question
Whoever use GIMP just to open jpegs to look inside his SD-card has no idea of GIMP's abilities. They better should use MS Photo editor.
That is true, one should NOT just open GIMP "in vain". MS Photo and Fax Viewer is more than sufficient if all you need to do is browse a directory of standard image files -- or, better yet, tell Windows Explorer to use "Thumbnails" view and you don't have to open any separate applications at all.
The only times I've opened GIMP and done nothing with it are when I was thinking of a task but changed my mind later on.
Hi friends,
Konrad
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
