Bucket Fill Tool won't filled selected
Bucket Fill Tool won't filled selected billlee 15 Jul 03:37
  Bucket Fill Tool won't filled selected scl 15 Jul 04:41
   Bucket Fill Tool won't filled selected billlee 15 Jul 05:30
  Bucket Fill Tool won't filled selected Thomas Taylor 15 Jul 05:06
   Bucket Fill Tool won't filled selected billlee 17 Jul 23:33
2013-07-15 03:37:17 UTC (almost 12 years ago)
GIMP 2.8.6 on Window 8.
I used Canvas Size to add a horizontal space at the bottom of a jpeg photo. (I want to use it for a text caption for the photo.) The new space is filled with a checkerboard of small light & dark grey squares.
I used the Rectangle Select Tool to select the new space.
I clicked on the Bucket Fill Tool and moved the mouse over the new space. The mouse pointer includes a circle with a diagonal stroke through it, indicating I cannot fill the selected area.
What am I doing wrong or missing?? (Probably something simple--I'm a GIMP newbie....)
Many thanks!! Bill
scl
2013-07-15 04:41:39 UTC (almost 12 years ago)
The problem is that with the default settings there's no layer area in that newly created, free space.
The easiest way is to 1. Go back before the Image/Canvas Size... step, 2. set the color you want to have in your horizontal space (for instance white) as background color,
3. in Image/Canvas Size..., listbox 'Resize layers' choose 'All layers'. I assumed you have only one layer. Otherwise another option except 'None' would be appropriate.
You save the Bucket Fill step to achieve the same and in future you can start with step 2.
4. Optional: If you want to fill your space with a gradient or similar use the Rectangle Select Tool or Fuzzy select tool, select the space and fill the selection according to your needs.
Kind regards,
Thomas Taylor
2013-07-15 05:06:02 UTC (almost 12 years ago)
Many thanks!! Bill
Hi Bill.
You see the checkerboard because the layer is set as a transparency (without color). After enlarging the canvas, try creating a new layer with the background color you wish then position it at the bottom of the enlarged canvas.
Tom
Insight comes more often than not, from looking at what's been on the table
all along.
  -  David McCullough
Tom Taylor - retired penguin - KG7CFC
AMD Phenom II x4 955 -- 4GB RAM -- 2x1.5TB sata2
openSUSE 12.3-x86_64
KDE 4.10.00, FF 19.0, claws-mail 3.9.1
registered linux user 263467
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.19 (GNU/Linux)
iQEcBAEBAgAGBQJRWnjBAAoJEHjxEe80vkwITlwIAPb2aBryi1pBNtlTTL87E1cB
+71yW5BbhS26IBkqy5o+u/KUdJGEQZ3kFcNn+7IFcTlhUMfmbz17GiVP60g2e9gW
D91lvWyTH7CA+1pKoHAMtjK+U6KC9uclnWRObYPHHJjDyLdJBoRDD6r8SYn4fdiD
dFRoV9tYhTRJYu170py6DybQ98qHnOe4uOO9Occdv34wXNcylPU4MOaUrFaFIqEF
QyUwaQCzkUreLewUb65O/2FkyHZCsYIC+P7rDhTkNOHywb14urwZ7AfQ964dxLj4
Cnnc6LgI4+MFJeB8oxwyCWDC0Jx+DjuF4rhg981aRnqCZYa5HryDAQLD2BkYCZs=
=nzdf
-----END PGP SIGNATURE-----
2013-07-15 05:30:28 UTC (almost 12 years ago)
[snip]
Kind regards,
That's perfect, thanks so much Sven!
This is my first time to use gimpusers.com/forums and I have to say I'm impressed with the promptness and the quality of the response!!!! :) :)
2013-07-17 23:33:43 UTC (almost 12 years ago)
Thank you very much, Tom! Now I have two ways to accomplish this, and you've also taught me some other stuff about GIMP. :) Namaste! ..Bill..
