Invert alpha channel
Invert alpha channel Mikael Ståldal 12 Jul 20:43
  Invert alpha channel Pat David 12 Jul 21:29
  Invert alpha channel Eduard Braun 12 Jul 22:15
  Invert alpha channel Ville Pätsi 13 Jul 06:41
   Invert alpha channel scl 15 Jul 15:19
Mikael Ståldal
2013-07-12 20:43:46 UTC (over 12 years ago)
Is there an easy way in GIMP to invert the alpha channel of an image? Transparent should be opaque, opaque should be transparent, almost transparent should be almost opaque, etc.
Pat David
2013-07-12 21:29:59 UTC (over 12 years ago)
Layer -> Transparency -> Alpha to Selection. Save as channel.
Apply as layer mask.
Invert.
Does that help?
On Fri, Jul 12, 2013 at 3:43 PM, Mikael Stldal wrote:
Is there an easy way in GIMP to invert the alpha channel of an image? Transparent should be opaque, opaque should be transparent, almost transparent should be almost opaque, etc. ______________________________**_________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/**mailman/listinfo/gimp-user-** list
pat david
http://blog.patdavid.net
Eduard Braun
2013-07-12 22:15:28 UTC (over 12 years ago)
Am 12.07.2013 22:43, schrieb Mikael Stldal:
Yes, there is:
1. Choose "Colors -> Components -> Decompose" from the menu and set "Color model" to "RGBA".
2. A new image is opened with all color channels (including alpha channel) decomposed as single layers. 3. Select the layer "alpha" and choose "Colors -> Invert" from the menu. 4. Choose "Colors -> Components -> Compose" from the menu, set "Color model" to "RGBA" and make sure the layers are correctly mapped to the channels (should be given if you did not reorder the layers)
Regards Eduard
Ville Pätsi
2013-07-13 06:41:09 UTC (over 12 years ago)
Quickest way is to right click on the layer and choose "Add Layer Mask". From there choose "Transfer layer's alpha channel". Then select the newly created mask and do Invert from the Colors menu. You can then apply the mask if you want.
-- Ville Ptsi
scl
2013-07-15 15:19:30 UTC (over 12 years ago)
Then tick the 'Invert mask' checkbox in the 'Add Layer Mask' dialog and save the Colors/Invert step ;-)
Kind regards
