[Fwd: RE: gimp long opening after changing the settings]
[Fwd: RE: gimp long opening after changing the settings] gimp@jbmd.com 04 Jul 17:18
  [Fwd: RE: gimp long opening after changing the settings] Richard Gitschlag 05 Jul 04:13
gimp@jbmd.com
2013-07-04 17:18:56 UTC (almost 12 years ago)
Even that was very good advice! I downgraded to 2.8.0 and am happy camper :-)
Thanx to Stratadrake
----------------------------- Pvodn zprva ----------------------------- Pedmt: RE: [Gimp-user] gimp long opening after changing the settings Od: "Richard Gitschlag"
Datum: 4 ervenec 2013, 15:40
Komu: "gimp@jbmd.com"
"gimp-user-list@gnome.org" --------------------------------------------------------------------------
Date: Thu, 4 Jul 2013 10:32:20 +0200 From: gimp@jbmd.com
To: gimp-user-list@gnome.org
Subject: [Gimp-user] gimp long opening after changing the settings
I changed settings in GIMP program, specifically the path to the palletes. Right after that GIMP started opening many minutes. Then I changed the path to the original one (didnt help), then I uninstalled and installed and it is still taking for ages to open this program. I am desperate. Should I edit registry or what should I do?
Thank you for any advice.
pm
If we had a dollar for every time somebody thinks uninstalling/reinstalling will ever solve anything....
There seems to be an issue in GIMP 2.8.6 with plugins during its startup routine where it manually queries every plugin at every startup (instead of just checking for new/updated plugins like it should do).
Richard Gitschlag
2013-07-05 04:13:44 UTC (almost 12 years ago)
Date: Thu, 4 Jul 2013 19:18:56 +0200 From: gimp@jbmd.com
Subject: [Gimp-user] [Fwd: RE: gimp long opening after changing the settings]
2.8.4 should work fine -- the "querying plug-ins" issue seems to have started with 2.8.6 .
