resynthesizer download and installation
8 of 8 messages available
resynthesizer download and installation realrisk2 02 Jul 15:16
  resynthesizer download and installation Kasim Ahmic 02 Jul 15:30
   resynthesizer download and installation realrisk2 02 Jul 15:47
   resynthesizer download and installation Bob Long 02 Jul 23:38
    resynthesizer download and installation Kasim Ahmic 03 Jul 01:30
     resynthesizer download and installation Alexandre Prokoudine 03 Jul 01:32
      resynthesizer download and installation Bob Long 03 Jul 03:13
       resynthesizer download and installation Kasim Ahmic 03 Jul 04:44
2013-07-02 15:16:30 UTC (over 11 years ago)
I am new to GIMP. And that shows. I want to use resynthesizer with Gimp 2.8.6. I downloaded something from the web (https://github.com/bootchk/resynthesizer) but this is a master without .exe file. Can somebody help me with the proper download and the installation in GIMP?
Kasim Ahmic
2013-07-02 15:30:49 UTC (over 11 years ago)
You want Resynthesizer 1.0: http://registry.gimp.org/node/27986
Sent from my iPod
-- realrisk2 (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
2013-07-02 15:47:14 UTC (over 11 years ago)
Sent from my iPod
THANKS!!!!!
Problem solved. Now I can heal myself.
Bob Long
2013-07-02 23:38:28 UTC (over 11 years ago)
Kasim Ahmic wrote,
And look at http://registry.gimp.org/node/15118
Bob Long
Kasim Ahmic
2013-07-03 01:30:17 UTC (over 11 years ago)
That's from 2009. I'm not entirely sure it'll work with Resynthesizer 1.0.
Sent from my iPod
On Jul 2, 2013, at 7:38 PM, Bob Long wrote:
Kasim Ahmic wrote,
-- Bob Long
2013-07-03 01:32:44 UTC (over 11 years ago)
And rightfully so :) Lloyd rewrote the original Resynthesizer into a back-end and a front-end.
Bob Long
2013-07-03 03:13:59 UTC (over 11 years ago)
Alexandre Prokoudine wrote,
On Wed, Jul 3, 2013 at 5:30 AM, Kasim Ahmic wrote, after I suggested:
I'm not sure I understand that comment.
Nor am I sure just what I have installed (Ubuntu 12.04/GIMP 2.8.6)!
I definitely installed http://registry.gimp.org/node/15118 recently. I can't recall if I also had to install Resynthesiser, or, if I did, what version.
Anyway, Help|Plug-in Browser tells me:
Resynthesize (plug-in-resynthesizer) ...
Author: Paul Francis Harrison
Date: 2000
and...
Heal selection (script-fu-smart-remove) ...
Author: Paul Harrison (pfh@logarithmic.net) Date: 13/9/2000
Copyright: Copyright 2000 Paul Harrison, 2009 Lloyd Konneker
Heal selection certainly works for me.
So what does that all mean?
Bob Long
Kasim Ahmic
2013-07-03 04:44:07 UTC (over 11 years ago)
From what I know, GIMP 2.8.x isn't compatible with any version of Resynthesizer other than v1.0. Resynthesizer v1.0 was entirely rewritten to support GIMP 2.8 and most likely included bug fixes/new features. Since you say you installed the "fix" from 2009, you have most likely downgraded the Heal Selection tool.
What you want to do is remove the current Resynthesizer plugin you have and install this one: http://registry.gimp.org/node/25219
It's not entirely necessary for you to upgrade if it works fine but I'd recommended it to keep issues from arising in the future.
Sent from my iPod
Date: 2000
and...
-- Bob Long
