Feature Request: Custom Colors for Light & Dark Checks
Feature Request: Custom Colors for Light & Dark Checks Akovia 30 Jun 02:26
Akovia
2013-06-30 02:26:18 UTC (almost 12 years ago)
I think this is the easiest way to achieve what I am seeking, but if another way is better, I'm open to suggestions. In short, I moderate a lot of images for fanart.tv and would like the ability to have gimp use my default (darker) theme color for normal operation of my padding color. When I am moderating I would like to be able to hit a shortcut to make the padding color pure white so I can check for cropped drop shadows and such easily. The quickest way I've found so far is shortcuts to "From Theme" and "Select Custom Color", in which I must select the color instead of having it already set. Light and Dark Checks seem perfect for this type of usage but I can't find a way to set the colors to what I need.
I asked for help at gimpchat.com http://www.gimpchat.com/viewtopic.php?f=8&t=7714&p=100062#p100062, and though I got some decent suggestions, I'm still searching for a way to achieve this. I'm not opposed to hacking a bit as long as I don't have to recompile, but thought this might be a useful feature for others as well.
Many Thanks for you consideration
-- View this message in context: http://gimp.1065349.n5.nabble.com/Feature-Request-Custom-Colors-for-Light-Dark-Checks-tp39136.html Sent from the Users mailing list archive at Nabble.com.
