Some problems after upgrading to 2.8.2 via Debian wheezy
Some problems after upgrading to 2.8.2 via Debian wheezy Martin Cracauer 24 Jun 12:57
  Some problems after upgrading to 2.8.2 via Debian wheezy Pat David 24 Jun 14:06
Martin Cracauer
2013-06-24 12:57:48 UTC (almost 12 years ago)
I have a couple issues after inheriting GIMP 2.8.2 via Debian wheezy. Most are system related, just posting here in case anyone else sees them and maybe can point me to existing bug reports.
Apart from Control-Shit-E remapping... (what you thinking, guys? :-)
1)
Typ: 'Alt-C' (enter "color" menu)
'C' (to get "color curves")
is broken because a second menu entry "Color Tint" uses plain C
2)
Many of the sliders don't behave well, let's say brush opacity. Sometimes the slider is locked in a state where moving it requires a lot more mouse movement. To get the slider to 50% I don't have to move the mouse into the middle of the slider, I have to move the mouse into the middle of the screen. This looks more like a GtK bug, or maybe my gtk settings are messed up? Running gnome-settings-demon or not running it makes no difference.
Apart from that but, is there a way to switch back to sliders that have a handle instead of these flat ones?
3)
For pictures written from Rawtherapee 4.11 I now have to wait for this after reading the TIFF. It's longer than the actual load.
lcms: converting from 'RT_sRGB gamma sRGB(IEC61966 equivalent)' to 'sRGB built-in'
I guess I'll take that up with the Rawtherapee guys? Looks related but isn't a straight "how do I not use RT_sRGB?": https://code.google.com/p/rawtherapee/issues/detail?id=1748
4)
This one's for the Debian guys but in case anyone else sees it:
GEGL-geglmodule.c-Message: Module '/usr/lib/x86_64-linux-gnu/gegl-0.2/ff-load.so' load error: /usr/lib/x86_64-linux-gnu/libavcodec.so.53: undefined symbol: lame_set_VBR_quality
Martin
Martin Cracauer    http://www.cons.org/cracauer/
Pat David
2013-06-24 14:06:34 UTC (almost 12 years ago)
Hi Martin,
1) It sounds like you may have a plugin/script installed that has stolen the "C" character focus. (I don't have a "Color Tint" option in my color menu...). You can modify the script if needed to correct this.
2) The sliders are actually very slick now, but may take a little getting used to: The top 50% of the slider is for 1:1 value adjustments, the bottom 50% of the slider is for finer value modifications (you should get a different cursor when hovering over the different portions). You can still get the old 1:1 modifications by hovering/clicking on the top half of the slider widget.
3) This one I am not sure of - perhaps you could just use the RT_sRGB profile in GIMP to avoid it? (Not 100% sure here, I've always let it convert, and it's been pretty quick for me).
1)
2)
3)
4)
Martin
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Martin Cracauer http://www.cons.org/cracauer/ _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
