Chromatic aberration plugin does not work
Chromatic aberration plugin does not work tikimir 21 Jun 19:46
  Chromatic aberration plugin does not work Pat David 21 Jun 20:03
   Chromatic aberration plugin does not work Partha Bagchi 21 Jun 20:14
    Chromatic aberration plugin does not work Pat David 21 Jun 20:27
    Chromatic aberration plugin does not work Alexandre Prokoudine 22 Jun 04:15
2013-06-21 19:46:22 UTC (almost 12 years ago)
Hello gimpologists,
I work with GIMP 2.8.4 on Windows XP. In order to remove strong lateral chromatic aberrations I tried the CA plugin version 3x What I saw in the preview looked good, but when I pressed the OK button no result appeared. What is the reason?? Can You also tell me please where to find and how to install this plugin on Suse Linux step by step. I am an absolute beginner. With many thanks in advance for Your help! Tikimir
Pat David
2013-06-21 20:03:55 UTC (almost 12 years ago)
Sorry, I'm not familiar with this plugin, but wanted to say that if you're looking for an automated means of fixing CA in your images, I've always had great results from using tca_correct (part of the Hugin panoramic processing software): http://hugin.sourceforge.net/
There's builds for all major OS's there. They even have a nice tutorial on using tca_correct on their site:
http://hugin.sourceforge.net/tutorials/tca/en.shtml
Perhaps that could be useful?
On Fri, Jun 21, 2013 at 2:46 PM, tikimir wrote:
Hello gimpologists,
is the reason??
tikimir (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Partha Bagchi
2013-06-21 20:14:45 UTC (almost 12 years ago)
Pat,
CA is part of my builds. :)
You will find it under Filters -> Colors -> Chromatic Aberration
Partha
Hello gimpologists,
the
appeared.
What
is the reason??
Pat David
2013-06-21 20:27:31 UTC (almost 12 years ago)
Well, there ya go! :) Go get one of Partha's builds...
On Fri, Jun 21, 2013 at 3:14 PM, Partha Bagchi wrote:
Pat,
Partha
Hello gimpologists,
the
appeared.
What
is the reason??
2013-06-22 04:15:04 UTC (almost 12 years ago)
On Sat, Jun 22, 2013 at 12:14 AM, Partha Bagchi wrote:
Pat,
Another alternative on Windows seems to be https://code.google.com/p/gimp-extensions/
