Gimp 2.1.3 Compile fail
Gimp 2.1.3 Compile fail | Matthew Daubenspeck | 08 Aug 18:29 |
Gimp 2.1.3 Compile fail | Justin Gombos | 08 Aug 19:02 |
Gimp 2.1.3 Compile fail | Sven Neumann | 08 Aug 19:41 |
Here is the error:
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include -DG_LOG_DOMAIN=\"LibGimpWidgets\" -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -mcpu=athlon-xp -O3 -pipe -Wall -MT gimpwidgets-private.lo -MD -MP -MF .deps/gimpwidgets-private.Tpo -c gimpwidgets-private.c -fPIC -DPIC -o .libs/gimpwidgets-private.o
if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include -DG_LOG_DOMAIN=\"LibGimpWidgets\" -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -mcpu=athlon-xp -O3 -pipe -Wall -MT test-preview-area.o -MD -MP -MF ".deps/test-preview-area.Tpo" \
-c -o test-preview-area.o `test -f 'test-preview-area.c' || echo './'`test-preview-area.c; \
then mv -f ".deps/test-preview-area.Tpo" ".deps/test-preview-area.Po"; \
else rm -f ".deps/test-preview-area.Tpo"; exit 1; \
fi
make[2]: *** No rule to make target `../libgimpwidgets/libgimpwidgets-2.0.la', needed by `test-preview-area'. Stop.
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3/libgimpwidgets'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3'
make: *** [all] Error 2
Any ideas?
* Matthew Daubenspeck [2004-08-08 09:41]:
Here is the error:
gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include -DG_LOG_DOMAIN=\"LibGimpWidgets\" -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -mcpu=athlon-xp -O3 -pipe -Wall -MT gimpwidgets-private.lo -MD -MP -MF .deps/gimpwidgets-private.Tpo -c gimpwidgets-private.c -fPIC -DPIC -o .libs/gimpwidgets-private.o if gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/X11R6/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include -DG_LOG_DOMAIN=\"LibGimpWidgets\" -DGIMP_DISABLE_DEPRECATED -DG_DISABLE_DEPRECATED -DGDK_PIXBUF_DISABLE_DEPRECATED -DGDK_DISABLE_DEPRECATED -DPANGO_DISABLE_DEPRECATED -DGDK_MULTIHEAD_SAFE -DGTK_MULTIHEAD_SAFE -mcpu=athlon-xp -O3 -pipe -Wall -MT test-preview-area.o -MD -MP -MF ".deps/test-preview-area.Tpo" \ -c -o test-preview-area.o `test -f 'test-preview-area.c' || echo './'`test-preview-area.c; \ then mv -f ".deps/test-preview-area.Tpo" ".deps/test-preview-area.Po"; \ else rm -f ".deps/test-preview-area.Tpo"; exit 1; \ fi make[2]: *** No rule to make target `../libgimpwidgets/libgimpwidgets-2.0.la', needed by `test-preview-area'. Stop. make[2]: *** Waiting for unfinished jobs.... make[2]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3/libgimpwidgets' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3' make: *** [all] Error 2
Any ideas?
I've never compiled gimp before, so this is a SWAG, but it looks like a Makefile problem.
Did you run .configure, if there is one?
Did you search the makefile for a rule for making libgimpwidgets-2.0.la to see if it's there? That's where I would start. Also, the trailing version number may be specified with a variable, so I would make sure there isn't a mismatch there.
Matthew Daubenspeck writes:
Here is the error:
make[2]: *** No rule to make target `../libgimpwidgets/libgimpwidgets-2.0.la', needed by `test-preview-area'. Stop. make[2]: *** Waiting for unfinished jobs.... make[2]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3/libgimpwidgets' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/var/tmp/portage/gimp-2.1.3/work/gimp-2.1.3' make: *** [all] Error 2Any ideas?
The problem only should only show up in parallel builds (make -j) and it has already been fixed in CVS. Just try a simple 'make'.
