Fw: A Sad case of regression.
Fw: A Sad case of regression. Alex Vergara Gil 14 Jun 19:06
  Fw: A Sad case of regression. Renaud OLGIATI 14 Jun 21:09
Alex Vergara Gil
2013-06-14 19:06:38 UTC (almost 12 years ago)
You've never heard of Adobe Premiere, Kdenlive, Apple Final Cut, Apple Logic, Audacity, Cubase, Ardour, Blender? That's OK. Now you have
Using the examples of video editing packages is rather disingenuous as they are all project based programs that work on the expectation of combining multiple files and outputting in a different format. A very different case.
Not so different:
Imagine that you have a jpg image and you want to add a png layer to it then in which format the GIMP must "save" the work.....yeah xcf. So I really think xcf shall be the default "save" option, now when you speak of "save as" things became philosophycal in which definition of what save as means is primordial. So to avoid all of this the export way is OK.
Care to give any examples of the genre of image editing programs that insist on defaulting to working on intermediate formats ?
What became annoying here is that GIMP means GNU IMAGE Manipulation Program, not GNU XCF Manipulation Program. So the only annoying thing that remains is the name, but I think for historical reasons it shouldnt be changed. As for programs that work on intermediate formats, I think every other program do this, even photoshop (remember psd).
Sometimes it's better to accept a program's development has gone wrong and return it to a more acceptable workflow that matches the expectations of it's users.
Sometimes its better to accept a programs user has gone wrong and accept the correct workflow that allows more productivity and less mistakes. I speak for myself here, since I was a detractor of this way of save/export and now I can live better thank to this kind of workflow.
Paul Holman
www.colourprofiles.com
Renaud OLGIATI
2013-06-14 21:09:46 UTC (almost 12 years ago)
Sometimes it´s better to accept a program´s user has gone wrong and accept the correct workflow that allows more productivity and less mistakes.
What is wrong with offering users the choice, and letting them decide on what they prefer, which way they would rather work ?
Thanks $DEITY I have now found Akkana's Save/export clean plug-in, which goes a long way towards mitigating the inconvenience imposed on some of the users by the developers.
Cheers,
Ron.
PS: http://shallowsky.com/software/gimp-save/
Il est plus honteux de se défier de ses amis que d'en ètre trompé.
                                               -- Duc de Larochefoucault
                   -- http://www.olgiati-in-paraguay.org --
