drop shadow
| drop shadow | Helen | 04 Jun 02:32 |
| drop shadow | Steve Kinney | 04 Jun 03:50 |
| drop shadow | Helen | 04 Jun 13:39 |
| drop shadow | Richard Gitschlag | 04 Jun 14:38 |
drop shadow
I have an image with two rectangular photos, in separate layers.
I want each photo to have a drop shadow. No matter what I do,
I keep getting the drop shadow applied to the entire image, not
to the layers. I've tried creating the drop shadow while on the
individual layers, while on the background, I've tried it with
layers selected -- regardless of what I do, the drop shadow
keeps applying to the entire image.
I used to know how to do this!
Help? Suse 12.3, gimp 2.8
Thanks much
Helen Etters using Linux, suse12.3
drop shadow
On 06/03/2013 10:32 PM, Helen wrote:
I have an image with two rectangular photos, in separate layers. I want each photo to have a drop shadow. No matter what I do, I keep getting the drop shadow applied to the entire image, not to the layers. I've tried creating the drop shadow while on the individual layers, while on the background, I've tried it with layers selected -- regardless of what I do, the drop shadow keeps applying to the entire image.
Hey Helen,
You might want to try doing Layers > Autocrop Layer against the layers with photos in them, before using a drop shadow plugin on them. That might do the trick.
Or make the shadows yourself - this would be my approach:
1. Create a new transparent layer, move it below the two layers with photos in them.
2. Select one of the layers with a photo in your Layers dock, right click the layer thumbnail and do "Alpha to selection"
3. Select the new transparent layer, drag and drop to the main canvas to fill the selection with black.
4. Select the other layer with a photo, right click and do "Alpha to selection" again.
5. Select the new transparent layer, drag and drop to fill the 2nd selection with black.
6. Do Select > None (or control + alt + a) to clear the selection.
Your transparent layer now has two black rectangles, hidden under the photos in the layers above. Use the tool at Filters > Blur > Gaussian Blur to soften the edges of the shadow rectangles, then turn on the Move tool in your main toolbox and use the arrow keys on your keyboard to tweak the location of the shadows. Adjust the shadow layer's transparency if required.
:o)
Steve
drop shadow
Steve, that's wonderful -- hand roll my own shadows! Seems so simple and
obvious after it's explained that I wonder why I ever thought I needed a
plug-in for this.
So cool!
Thanks, Steve
Help? Suse 12.3, gimp 2.8Hey Helen,
:o)
Steve
gimp-user-list@gnome.org
drop shadow
Date: Mon, 3 Jun 2013 22:32:39 -0400 From: etters.h@gmail.com
To: gimp-user-list@gnome.org
Subject: [Gimp-user] drop shadowI have an image with two rectangular photos, in separate layers. I want each photo to have a drop shadow. No matter what I do, I keep getting the drop shadow applied to the entire image, not to the layers. I've tried creating the drop shadow while on the individual layers, while on the background, I've tried it with layers selected -- regardless of what I do, the drop shadow keeps applying to the entire image.
Thanks much
I'm curious how this is even happening in the first place, because from my experience the drop shadow uses, in order:
1 - If you have a selection, it creates a shadow based on the selection mask. 2 - Or, if your layer has an alpha channel, it uses that. 3 - Otherwise, it uses the entire current layer.
It's true that performing your own shadows is completely doable, but if it's something you do a lot then having an automated script/plug-in for it does save you a lot of work. (Assuming it functions correctly, of course.)
Do you have screenshots of what your results are? If it's creating a drop shadow around the entire image border then the most obvious problem would normally be not having the correct layer selected before executing it (or having layer boundaries extended to the whole image).
-- Stratadrake
strata_ranger@hotmail.com
