EXIF-data not saved
EXIF-data not saved Oskar Eyb 05 Aug 15:28
  EXIF-data not saved Dave Neary 05 Aug 18:16
  EXIF-data not saved Sven Neumann 05 Aug 23:46
EXIF-data not saved William Skaggs 05 Aug 22:09
  EXIF-data not saved Oskar Eyb 01 Jan 02:05
Oskar Eyb
1997-01-01 02:05:15 UTC (over 28 years ago)
EXIF-data not saved
On Thu, Aug 05, 2004 at 01:09:23PM -0700, William Skaggs wrote:
thanks for you reply.
Yes, you are right that it does not work: this is one of the main reasons why Gimp 2.0.4 is going to be released very soon -- in the next few days. It worked in 2.0.2, and it will work again in 2.0.4.
Okay, I'll look for updates.
Oskar
Oskar Eyb
2004-08-05 15:28:53 UTC (over 20 years ago)
EXIF-data not saved
the checkbox "Save EXIF data" is activated, but after saving the file doesn't contain EXIF data any longer.
GIMP 2.0.3 Win32
Greets, Oskar
Dave Neary
2004-08-05 18:16:51 UTC (over 20 years ago)
EXIF-data not saved
Hi Oskar,
Check that you have libexif installed, and that your JPEG plug-in is linked to it.
Cheers,
Dave.
Quoting Oskar Eyb :
GIMP 2.0.3 Win32
Greets, Oskar
William Skaggs
2004-08-05 22:09:23 UTC (over 20 years ago)
EXIF-data not saved
GIMP 2.0.3 Win32
Yes, you are right that it does not work: this is one of the main reasons why Gimp 2.0.4 is going to be released very soon -- in the next few days. It worked in 2.0.2, and it will work again in 2.0.4. See http://bugzilla.gnome.org/show_bug.cgi?id=148632 for more information.
Best,
-- Bill
2004-08-05 23:46:42 UTC (over 20 years ago)
EXIF-data not saved
Oskar Eyb writes:
GIMP 2.0.3 Win32
That's a known problem in GIMP 2.0.3 and it will be fixed in the upcoming 2.0.4 release.
