Raw Therapee batch process
Raw Therapee batch process Byram 29 Apr 00:38
  Raw Therapee batch process Alexandre Prokoudine 29 Apr 01:06
   Raw Therapee batch process Partha Bagchi 29 Apr 01:21
2013-04-29 00:38:49 UTC (almost 12 years ago)
Raw Therapee is a great tool, but I find the documentation befuddling. I'd like to convert about 100 Nefs to 16 bit pgn. I'm not making edits at this time, but would also be interested in knowing what my optional line would be to apply a batch edit.
thanks
2013-04-29 01:06:50 UTC (almost 12 years ago)
Hi Byram,
Is that a GIMP question? :) I suppose it's not.
Anyway, if you have UFRaw installed, you can run 'ufraw-batch' from console. The '--help' key will output all the available options.
Partha Bagchi
2013-04-29 01:21:47 UTC (almost 12 years ago)
Not unless Gimp started incorporating RT. :)
To the OP:
A simple Google search would have located the following:
http://scribble-jpc.blogspot.com/2011/08/raw-therapees-batch-processing-to.html
Or please post in the RT forum.
On Sun, Apr 28, 2013 at 9:06 PM, Alexandre Prokoudine < alexandre.prokoudine@gmail.com> wrote:
I'd
this
would be to
apply a batch edit.
Hi Byram,
gimp-user-list@gnome.org
