how to draw interrupted lines
6 of 7 messages available
EBCC3DF41520488381D467D9E8B... 05 Apr 20:15
  how to draw interrupted lines Daniel 05 Apr 20:12
   how to draw interrupted lines Richard Gitschlag 06 Apr 01:46
    how to draw interrupted lines Patrick Shanahan 06 Apr 03:29
     how to draw interrupted lines Michael Schumacher 06 Apr 09:11
      how to draw interrupted lines Patrick Shanahan 06 Apr 13:16
     how to draw interrupted lines Richard Gitschlag 06 Apr 13:50
Daniel
2013-04-05 20:12:35 UTC (about 12 years ago)
I am glad to have been of help.
The email was, unfortunately, too large for the list due to the numerous attached images.
Perhaps we could add this simple tutorial to some other body or knowledge. As you already have the write-up and the images, maybe you could submit it to GimpUsers.com.
On Fri, 2013-04-05 at 21:30 +0200, Uniklaps wrote:
Hi Daniel,
thank you for this complete instruction, simply great! This way saves lots of time!
Sorry to hear that you had a quiet morning at the office, but lucky for me, lol.
I wish you a great weekend!
Yours Konrad
-----Ursprüngliche Nachricht----- Von: Daniel [mailto:daniel@yacg.com] Gesendet: Freitag, 5. April 2013 14:52 An: 3052192
Cc: gimp-user-list@gnome.org
Betreff: Re: [Gimp-user] how to draw interrupted lines
Okay, quiet morning here at the office. So here goes:
1. Starting with a blank image (640x400 in this case) select the Paths tool
2. Click to draw four points. Put them anywhere you like, but I creatively decided to make an almost straight line.
3. Click and drag on any of the line segments you have created. You will notice little handles appear. These help create the curves we will be working with. (It's not "free hand" but you can get what you want this way.)
4. Move the handles around to get more dramatic or effective curves. Think of the length of the handles as power or influence over the path and the direction as the direction.
5. Here's the part you have been more interested in I'm sure. In the "Layers, Channels, Paths, Undo" window, select the third tab for "Paths" and note the "Unnamed" path there. Also note the tool buttons below the paths list. The one that looks like a paintbrush is "Paint along the path."
6. Click the Paint along the path tool and a "Stroke Path" dialog will appear. Look around and play with the options. I'm going with "Solid color" expanding the "Line Style" and selecting "Dash, dot, dot" as my dash preset. (You can create your own patterns)
7. Now click the "Stroke" button to see what it does. If you don't like it, do "Edit -> Undo" then go back to "5" to make some adjustment. It's just play, so do what you like! (I selected to "Move" tool to show the results better.)
So with each step you can see there are variables to play with and things you can adjust along the way. The path examples I illustrated give example of different types of curve patterns including a bulge, a loop and an S curve.
I suspect what you want to do is nothing like what I did. You may want to edit a map image or something like that. No problem. My favorite way to do this is to open the map image, add a new transparent layer on top, and start drawing on that. Changing colors for best effect and all that is good but I'm sure you knew that already.
I hope this was helpful for you and anyone else interested in this topic.
On Wed, 2013-04-03 at 19:19 +0200, 3052192 wrote:
Hi friends,
how can I draw in GIMP freehanded curved
interrupted lines (dotted; dot-dash-dot; dash-dash;...) ?
To create lines first with a pencil and to use then the rubber
gives uneven and so unsatisfactory results.
Thanks for help!
Konrad
Richard Gitschlag
2013-04-06 01:46:03 UTC (about 12 years ago)
To: uni.klaps@t-online.de
Date: Fri, 5 Apr 2013 16:12:35 -0400 CC: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] how to draw interrupted lines
*headdesk* Apparently, GIMP .gdyn files are more bloated than MS Word documents....
Patrick Shanahan
2013-04-06 03:29:24 UTC (about 12 years ago)
* Richard Gitschlag [04-05-13 21:46]:
perhaps you should try text instead of html/bloated/drivel
(paka)Patrick Shanahan       Plainfield, Indiana, USA      HOG # US1244711
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
http://en.opensuse.org                           openSUSE Community Member
2013-04-06 09:11:51 UTC (about 12 years ago)
NB: I'm considering to change the list configuration to drop the html parts of messages.
Patrick Shanahan
2013-04-06 13:16:43 UTC (about 12 years ago)
* Michael Schumacher [04-06-13 05:13]:
Would be a welcome change and if dropping the "html parts" is not feasible or easily accomplished, announcing and enforcing rejection of html post would be acceptable.
thankyou
Richard Gitschlag
2013-04-06 13:50:02 UTC (about 12 years ago)
Date: Fri, 5 Apr 2013 23:29:24 -0400 From: ptilopteri@gmail.com
To: gimp-user-list@gnome.org
No, it was solely the attachment that was at fault (see other topic on GIMP .gdyn files).
Numbers may not lie, but neither do they tell the whole truth. =
