HELP
HELP Mateusz Skutnik 10 Mar 00:02
  Menus can't be found (was: HELP) Michael Schumacher 11 Mar 19:30
  HELP Alexandre Prokoudine 11 Mar 21:03
Mateusz Skutnik
2013-03-10 00:02:10 UTC (about 12 years ago)
HELP
I can't find any of the menus. There doesn't seem to be an option which enables them either, unless it's hidden. How do I enable the menus?
2013-03-11 19:30:38 UTC (about 12 years ago)
Quick guess:
Try the View menu from the context menu - usually it can be accessed by the right mouse button. There's a 'show menubar' option.
If this isn't the problem, please elaborate.
P.S. please add a bit more information to the subject of a message
2013-03-11 21:03:55 UTC (about 12 years ago)
HELP
A quick possible solution is to right click inside an image window and use "View > Show Menubar" command, then check if "Show menubar" checkbox is disabled in "Edit > Preferences > Image Windows > Appearance".
