"Render" mode
"Render" mode Jonathan Melhuish 18 Jul 12:49
  "Render" mode Sven Neumann 18 Jul 13:39
Jonathan Melhuish
2004-07-18 12:49:13 UTC (almost 21 years ago)
"Render" mode
Is there any way that I can manipulate a smaller, screen-resolution version of the actual image (perhaps loading sections at a higher resolution as I zoom in), then "render" my edits on the actual file at a later date (eg. overnight).
It strikes me that it is very easy to produce a very large file, such as a panorama from several photographs scanned at 1200dpi, but very difficult to then edit it due to a lack of RAM. It'd be great if I could use the GIMP in the above manner; it would really open up opportunities for higher-quality work.
Apologies if this has already been discussed; the Archive search appears to be broken, and I wouldn't know what search terms to use anyway.
Cheers,
Jon PS: There's only one thing that bugs me about version 2.0; how do I assign shortcut keys?!
2004-07-18 13:39:45 UTC (almost 21 years ago)
"Render" mode
Jonathan Melhuish writes:
It has been discussed and it should be possible in some future version. I just can't tell you how long you will have to wait.
Enable "Dynamic Keyboard Shortcuts" in the preferences or edit the menurc manually. GIMP 2.2 will probably come with a convenient shortcut editor.
