HDR Render plugin not working!
| HDR Render plugin not working! | Christen Anderson | 27 Jan 22:49 |
| HDR Render plugin not working! | Partha Bagchi | 28 Jan 02:13 |
| HDR Render plugin not working! | Christen Anderson | 28 Jan 19:04 |
| HDR Render plugin not working! | Partha Bagchi | 29 Jan 02:04 |
| HDR Render plugin not working! | Partha Bagchi | 29 Jan 02:06 |
| HDR Render plugin not working! | Christen Anderson | 29 Jan 03:20 |
| HDR Render plugin not working! | Partha Bagchi | 29 Jan 10:15 |
| HDR Render plugin not working! | Partha Bagchi | 29 Jan 11:33 |
| HDR Render plugin not working! | Christen Anderson | 29 Jan 21:39 |
Hi everyone,
Running gimp 2.9 (Partha's build) on Windows Vista 32-bit.
I downloaded and installed the "HDR tone mapping plugin" from
http://registry.gimp.org/node/24310
But when I try to run it, I get the following error message:
An error occurred running python_fu_feca_hdr TypeError: 'NoneType' object is not subscriptable
Under "More Information" I see:
Traceback (most recent call last):
File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line
699, in response
dialog.res = run_script(params)
361, in run_script
return apply(function, params)
File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins\feca_hdr.py",
line 114, in python_feca_hdr
pixeln = pfn.get_pixel(col, row)
line 55, in get_pixel
return self.tile[coloff, rowoff]
Any ideas what could cause this?
tia, Christen
Behind the Feather Curtain
Hi Christen,
Can you tell me how you tried to run it? All the information you can provide would be helpful. In the meantime, I am going to download the plugin and see what the issue is.
Thanks, Partha
On Sun, Jan 27, 2013 at 5:49 PM, Christen Anderson < christenanderson1994@gmail.com> wrote:
Hi everyone,
Running gimp 2.9 (Partha's build) on Windows Vista 32-bit.I downloaded and installed the "HDR tone mapping plugin" from http://registry.gimp.org/node/24310
But when I try to run it, I get the following error message:An error occurred running python_fu_feca_hdr TypeError: 'NoneType' object is not subscriptable
Traceback (most recent call last): File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line 699, in response
File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script
File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins\feca_hdr.py", line 114, in python_feca_hdr
pixeln = pfn.get_pixel(col, row) File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins\feca_hdr.py", line 55, in get_pixel
return self.tile[coloff, rowoff] TypeError: 'NoneType' object is not subscriptableAny ideas what could cause this?
tia, Christen
Behind the Feather Curtain_______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
On 1/27/2013 7:13 PM, Partha Bagchi wrote:
Hi Christen,
Thanks, Partha
On Sun, Jan 27, 2013 at 5:49 PM, Christen Anderson > wrote:
Hi everyone,
Running gimp 2.9 (Partha's build) on Windows Vista 32-bit.I downloaded and installed the "HDR tone mapping plugin" from http://registry.gimp.org/node/24310 But when I try to run it, I get the following error message:
dialog.res = run_script(params) File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script
return apply(function, params) File "C:\Program
tia, Christen
Hi Partha,
Sorry for the delayed response. I just dropped the .py file in my
plug-ins folder (C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins),
booted Gimp, and selected Python-Fu --> Render --> HDR Tone Mapping. I
ran the plugin with the default values and got the error message.
~Christen
Hi Christen,
Can you delete the version you downloaded and use the attached version?
Just unzip into the plugin directory as you did before.
Note that as of Gimp 2.9, the location of your personal directory has changed. On Windows 7 it is C:\Users\Username\AppData\Roaming\GIMP\2.9. I don't know the location on Vista.
Please let me know if this does not work for you or you get any errors.
Thanks, Partha
On Mon, Jan 28, 2013 at 2:04 PM, Christen Anderson < christenanderson1994@gmail.com> wrote:
Hi Christen,
Thanks, Partha
Hi everyone,
tia, Christen
Hi Partha,
Sorry for the delayed response. I just dropped the .py file in my plug-ins folder (C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins), booted Gimp, and selected Python-Fu --> Render --> HDR Tone Mapping. I ran the plugin with the default values and got the error message.~Christen
-- Behind the Feather Curtain
Oh, BTW, I didn't like the fact that the original created a whole new menu item. This version will be located at Filters -> Enhance -> HDR tone mapping
On Mon, Jan 28, 2013 at 9:04 PM, Partha Bagchi wrote:
Hi Christen,
Thanks, Partha
Hi Christen,
Thanks, Partha
Hi everyone,
tia, Christen
Hi Partha,
Hm... are you sure you sent me the right file? It's displaying the same behavior whenever I try to use it... And it is still located under Python-Fu/Render/HDR Tone Mapping... ~Christen
On Mon, Jan 28, 2013 at 9:04 PM, Partha Bagchi > wrote:
Hi Christen,
C:\Users\Username\AppData\Roaming\GIMP\2.9. I don't know the location on Vista.Please let me know if this does not work for you or you get any errors.
Thanks,
Hi Christen,
Thanks, Partha
Hi everyone, Running gimp 2.9 (Partha's build) on Windows Vista 32-bit.
tia, Christen
Hi Partha,
Sorry about that! :(
Here is the correct attachment.
Please let me know if it does not work.
On Mon, Jan 28, 2013 at 10:20 PM, Christen Anderson < christenanderson1994@gmail.com> wrote:
Hi Christen,
Thanks, Partha
Hi Christen,
Thanks, Partha
Hi everyone,
tia, Christen
Hi Partha,
https://mail.gnome.org/mailman/listinfo/gimp-user-list--
BTW, I have updated Gimp 2.9 to the latest git source (Jan 25, 2013). All versions and OSes are updated.
Please update.
Thanks, Partha
Hi Christen,
Thanks, Partha
Hi Christen,
Thanks, Partha
Hi everyone,
tia, Christen
Hi Partha,
Installed the latest version of Gimp and the new plugin... worked like a charm!! Thanks for all your work, Partha! I really appreciate it!
~Christen
Please update.
Thanks, Partha
Hi Christen,
Thanks, Partha
Hi Christen,
Thanks, Partha
Traceback (most recent call last): File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line 699, in response dialog.res = run_script(params) File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\python\gimpfu.py", line 361, in run_script return apply(function, params) File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins\feca_hdr.py", line 114, in python_feca_hdr pixeln = pfn.get_pixel(col, row) File "C:\Program Files\Gimp-2.9\lib\gimp\2.0\plug-ins\feca_hdr.py", line 55, in get_pixel return self.tile[coloff, rowoff] TypeError: 'NoneType' object is not subscriptable
tia, Christen
Hi Partha,
_______________________________________________ gimp-user-list mailing list gimp-user-list@gnome.org
