Missing Group Layers
7 of 7 messages available
Missing Group Layers Montrosity 17 Jan 23:06
  Missing Group Layers Madeleine Fisher 18 Jan 00:37
   Missing Group Layers Montrosity 18 Jan 03:30
    Missing Group Layers Madeleine Fisher 18 Jan 03:50
  Missing Group Layers Michael Schumacher 18 Jan 00:46
    Missing Group Layers Burnie West 18 Jan 06:16
2013-01-17 23:06:45 UTC (about 12 years ago)
I saved an image with over 10 layers, and most of those layers were in a group folder. When I reopened the image, the layers that were in the folder were missing. Those layers had hours of work put into them, and I cant afford to redo it. Is there any way to get those layers back?
Madeleine Fisher
2013-01-18 00:37:54 UTC (about 12 years ago)
WAIT, you can group layers in the Gimp now!?!?
HOW YOU MUST TEACH ME
animatrix1490
-- Montrosity (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
2013-01-18 00:46:24 UTC (about 12 years ago)
I've never seen a report like this. Are you able to reproduce this? Try a new small image, one that could potentially be attached to a bug report.
2013-01-18 03:30:19 UTC (about 12 years ago)
animatrix1490
In the layers tab, next to the icon where you can create a new layer, there is a little folder icon. When you click it, it creates a group layer where you can have multiple layers under the group. it is really handy when you have tons of layers. You can make multiple groups for each part of the piece.
2013-01-18 03:30:57 UTC (about 12 years ago)
Im not sure if I understand what you mean?
Madeleine Fisher
2013-01-18 03:50:50 UTC (about 12 years ago)
Oh my gosh, my life is awesome now.
Thank you so much!
animatrix1490
Burnie West
2013-01-18 06:16:09 UTC (about 12 years ago)
If you are not new to GIMP, then please ignore the following. I have not been able reproduce your problem.
Assuming you are new to GIMP, what I believe Michael meant was this:
Just do what you had done to create a layer group using a simple image, then save the file. If you started with a brand new .jpg, the fileyou saved will have the same name but with extension .xcf, and if you reopen the .jpg file it will be the one with which you started.You would need to open the .xcf file.
However, if you opened the file simple.jpg, did all your work on the layers in the layer group, and then instead of saving it you clicked on the file selection "Overwrite simple.jpg" the file saved would produce a jpg file with only one layer. If you then tried to close GIMP, it would post a dialog asking you "Save the changes to image 'simple.xcf' before closing?" If you thenclicked on "Close without Saving" because you had overwritten the jpg file, then all the layers would be lost and you would just have a single layer with all your changes consolidated.
In that case, there would be no way to recover the individual layers.
