drop-shadow
drop-shadow Andrew 07 Jul 13:08
  drop-shadow Brion Vibber 07 Jul 22:44
   drop-shadow Patrick Shanahan 07 Jul 23:07
   drop-shadow Alan Bailward 07 Jul 23:09
Andrew
2004-07-07 13:08:50 UTC (almost 21 years ago)
drop-shadow
Is it possible to add a drop-shadow to a png in such a way that certain browsers such as IE won't wreck the picture? TIA
Andrew
Brion Vibber
2004-07-07 22:44:09 UTC (almost 21 years ago)
drop-shadow
a) Just give it a solid background.
b) Make it solid immediately around the drop shadow, and cut off to transparent for the rest. (Save as indexed color.) Might look okay for a consistent, slightly varying background.
c) Use scary HTML/CSS hacks to show alpha-transparent PNGs in IE. Doesn't work on some versions, may crash, and may cause ActiveX security warnings. (Google up 'AlphaImageLoader')
-- brion vibber (brion @ pobox.com)
Patrick Shanahan
2004-07-07 23:07:06 UTC (almost 21 years ago)
drop-shadow
* Brion Vibber [07-07-04 15:44]:
That wouldn't necessarily be a *bad* thing.
Alan Bailward
2004-07-07 23:09:31 UTC (almost 21 years ago)
drop-shadow
If I remember right there is also a CSS file called "IE7" which you can add into your webpage to fix a lot of the problems with IE, mostly CSS, but it might (might!) also fix alpha blended PNG issues.
alan
