gif loop forever
gif loop forever Jonathan Chetwynd 06 Jul 21:03
  gif loop forever Roman Joost 09 Jul 14:27
Jonathan Chetwynd
2004-07-06 21:03:37 UTC (almost 21 years ago)
gif loop forever
The default action when saving a gif in gimp is loop forever
this would seem contrary to accessibility guidelines and advice which suggest that animations should not cycle. you could join us on:
irc://freenode/accessibility
thanks
Jonathan Chetwynd http://www.peepo.co.uk "It's easy to use" irc://freenode/accessibility
Roman Joost
2004-07-09 14:27:58 UTC (almost 21 years ago)
gif loop forever
Hi Jonathan,
On Tue, Jul 06, 2004 at 08:03:37PM +0100, Jonathan Chetwynd wrote:
The default action when saving a gif in gimp is loop forever this would seem contrary to accessibility guidelines and advice which suggest that animations should not cycle.
Could you point to the Guideline(s) which propose this behaviour? Are you refering to guidelines which cover web content, user agent or authoring tools?
Cheers,
