Resolution
3 of 4 messages available
086EDD091FDE4CABBCB210BAAD0... 15 Dec 09:16
  Resolution Richard Gitschlag 15 Dec 09:12
   REMOVE ME FROM THIS LIST!!!!! Stan Dawson 15 Dec 13:24
    REMOVE ME FROM THIS LIST!!!!! David Joyner 15 Dec 13:35
Richard Gitschlag
2012-12-15 09:12:41 UTC (almost 13 years ago)
Resolution
"Image > Print Size" really IS the command you are looking for.
The key is to pay attention to the units-of-measure shown on the Print Size dialogue box: - The "Width" and "Height" values under Print Size are displayed in real-world units (inches, mm, etc.), not image pixels. - The "Resolution" values are displayed in pixels-per-unit. - You cannot change your image's pixel dimensions (aka scale the image) from the Print Size dialogue. That's what the "Scale Image" command is for.
Remember the relation between pixel and print sizes is:
(print size) = (pixel size) / (print resolution)
When you change the image's print resolution, of course the real-world size (the "width" or "height" shown in the Print Size dialog) of your image will update to reflect the new print resolution -- that value is calculated from your image's actual pixel size and whatever resolution value you just entered. This is totally normal behavior -- in fact, it's expected. If you change an image's resolution from, say, 150 pixels/inch to 75 pixels/inch, this doubles the print size of your image but only the print size; the image's pixel size remains precisely the same as before. (You can confirm this by comparing "Image > Canvas Size..." before and after changing the resolution.)
And as others have stated, if you're using the image for Web viewing then its print resolution has absolutely zero effect on how it will appear onscreen (print resolution only affects, well, actual printing), in which case you'll want to use the "Scale Image" command to actually scale your image larger or smaller.
From: leon.white140@ntlworld.com To: strata_ranger@hotmail.com
Subject: Re: [Gimp-user] Resolution
Date: Fri, 14 Dec 2012 19:13:59 +0000
Thanks...but when I change the picture size the resolution changes..
and when I change the resolution the picture size changes..
There does not appear to be any way to unlock the two..
This is in image > print size
Leon
From: Richard Gitschlag Sent: Friday, December 14, 2012 5:58 PM To: leon.white140@ntlworld.com ; gimp-user-list@gnome.org Subject: RE: [Gimp-user] Resolution
It's under "Image > Print Size...".
Stratadrake
Numbers may
not lie, but neither do they tell the whole truth.
To: gimp-user-list@gnome.org
Date: Fri,
14 Dec 2012 17:27:35 +0000
Subject: [Gimp-user] Resolution
Is there a way to change the resolution of a picture without
it changing the size.
I cannot find a way to separate the two..
Thanks...Leon
gimp-user-list mailing list gimp-user-list@gnome.org
https://mail.gnome.org/mailman/listinfo/gimp-user-list 		 	   		  =
Stan Dawson
2012-12-15 13:24:26 UTC (almost 13 years ago)
--- On Sat, 12/15/12, Richard Gitschlag wrote:
From: Richard Gitschlag Subject: Re: [Gimp-user] Resolution
To: leon.white140@ntlworld.com, gimp-user-list@gnome.org Date: Saturday, December 15, 2012, 4:12 AM
Leon
From: leon.white140@ntlworld.com To: gimp-user-list@gnome.org
Date: Fri, 14 Dec 2012 17:27:35 +0000 Subject: [Gimp-user] Resolution
Is there a way to change the resolution of a picture without it changing the size.
Thanks...Leon
_______________________________________________ gimp-user-list mailing list gimp-user-list@gnome.org https://mail.gnome.org/mailman/listinfo/gimp-user-list -----Inline Attachment Follows-----
David Joyner
2012-12-15 13:35:53 UTC (almost 13 years ago)
***You*** have to read the instructions at the link at the bottom of each gimp-user email. So:
1) click on the link below 2) read the instructions
3) follow the instructions
