[Newbie] Fill with transparent color
[Newbie] Fill with transparent color Olivier Marie 05 Jul 13:34
  [Newbie] Fill with transparent color Dave Neary 05 Jul 16:26
Olivier Marie
2004-07-05 13:34:51 UTC (over 21 years ago)
Hello all,
I'm starting using GIMP 2.0.2 under winXP. It seems to be very powerfull !
I don't succeeded in filling a form with a transparent color (indexed image)
My questions are :
How can I fill a zone with transparent color ?
An erased zone (transparent) has an alpha value equal to 0. In the same image, others pixels can have the same index but with alpha=255. Can I have a specific transparent index ?
Thanks in advance
Olivier
Dave Neary
2004-07-05 16:26:58 UTC (over 21 years ago)
Salut et bienvenu :)
Quoting Olivier Marie :
My questions are :
First you need to add an alpha channel to your image. Then select the region you would like to erase, and Edit->Clear.
When you save the image as a GIF, this is what happens. To ensure that you have space for an indexed palette entry, you should select a 255 colour palette rather than a 256 color palette during indexing when you want an alpha channel.
PNG indexes differently, in that an index entry may have an alpha value from 0 to 255 associated with it, effectively allowing an RGBA palette. Unfortunately, the GIMP doesn't really support that properly (yet?).
Cheers, Dave.
