exporting to psd format issue
exporting to psd format issue samlive 26 Nov 06:55
  exporting to psd format issue Simon Budig 26 Nov 09:16
   exporting to psd format issue Guiu Rocafort 26 Nov 20:45
2012-11-26 06:55:09 UTC (over 12 years ago)
I'm a photoshop user designing some individual commercial works, and I've decided to try Gimp. The problem is the costumer want the project in psd format to edit it with photoshop so I tried an example to chick if it will export it or not. I designed an example and export it to psd, And I've got error message that Blendmodes can't be exported and here is the picture of the error message http://img805.imageshack.us/img805/7743/gimp28issue.jpg I've opened the image in photoshop and and I found all layers reset on Normal Mode. So is there any solution for my problem?
Simon Budig
2012-11-26 09:16:57 UTC (over 12 years ago)
Well - apart from the obvious answers (get your customers to use gimp, ask adobe to support the XCF file format) it probably needs changes to the gimp code.
Does photoshop actually support the "burn"/"grain-extract"/"grain-merge" layer modes? I have no idea, but if it does the PSD plugin needs to be changed to support these.
Bye, Simon
simon@budig.de              http://simon.budig.de/
Guiu Rocafort
2012-11-26 20:45:13 UTC (over 12 years ago)
I have took a look at the photoshop blend modes and there are a "color burn" and a "linear burn" blend mode. I'm not sure if one of these are equivalent.
The "grain-extract" and the "grain-merge" doesn't seem to have any equivalent in photoshop.
http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e41001031ab64-77eba.html#WSfd1234e1c4b69f30ea53e41001031ab64-77e9a
If one of the burn blend modes is equivalent to the one in gimp it should be easy to add support in the psd-export plugin. The grain-extract and grain-merge would require more work i guess..
Bye, Simon
simon@budig.de http://simon.budig.de/ _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
Please avoid sending me Word or PowerPoint attachments. See http://www.gnu.org/philosophy/no-word-attachments.html
