8x10 photo without cropping...
8x10 photo without cropping... jenn golden 16 Nov 21:30
  8x10 photo without cropping... Patrick Shanahan 16 Nov 21:43
   8x10 photo without cropping... jenn golden 16 Nov 22:54
  8x10 photo without cropping... Tobias Lunte 16 Nov 22:07
   8x10 photo without cropping... Daniel Smith 16 Nov 22:46
jenn golden
2012-11-16 21:30:02 UTC (over 12 years ago)
Hi - I am a bit of a newbie to this prog. And the issue I am having, is that I created a Magazine cover using my son's football pic. To make a long story short - I can create a fabulous 4x6, but when I try to send it out to blow up to an 8x10, it crops way too much of the cover... How do I save or edit the pic as an 8x10 so that I do not loose my added graphics and artwork? Please help! Any suggestions would be greatly appreciated!
Jenn
Patrick Shanahan
2012-11-16 21:43:11 UTC (over 12 years ago)
* jenn golden [11-16-12 16:32]:
from 4x6 to 8x10 is different ratio and either you loose some picture or have blank space. 4x6 expands to 8x12 or 6.67x10 An option, save your additions to a layer and shrink the layer to the dimentions to fit the intended size and merge the layer to 8x10
without carnival mirror type distortion, there is no easy change from 4x6 to 8x10.
(paka)Patrick Shanahan       Plainfield, Indiana, USA      HOG # US1244711
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
http://en.opensuse.org                           openSUSE Community Member
Tobias Lunte
2012-11-16 22:07:26 UTC (over 12 years ago)
Am 16.11.2012 22:30, schrieb jenn golden:
Jenn
gimp-user-list@gnome.org
I know, this might be a little bit too much for someone new to the program, but one of the better ways to do it would be installing and using the liquid rescale-plugin
(http://liquidrescale.wikidot.com/). It will scale the image instead of cropping it, so there won't be anything cut or borders added in. But other than the normal scale-tool, it tries to detect important parts of the image (like faces or text) and keeps their proportion the same.
Feel free to email me if you decide to do it this way and need some help.
bw, Tobl
Daniel Smith
2012-11-16 22:46:46 UTC (over 12 years ago)
I am assuming you're asking it this way too because you saved it as a flattened version of your work? I mean, if you have a version of it with all the layers as live text and added graphics still separate, you could just save or copy out another of the background pic and scale or resize to your wishes, and then re-add and size or position the text and/or graphics according to taste, right? Hoping you did save with layers intact somewhere. Daniel
Jenn
bw, Tobl
jenn golden
2012-11-16 22:54:01 UTC (over 12 years ago)
Thanks! I ended up uploading the original image, then used the website that is going to make the 8x10 to figure out where it was going to be cropped - then took my gimp creation and adjusted accordingly - at least now I know! :)
long
to
or
(paka)Patrick Shanahan Plainfield, Indiana, USA HOG # US1244711 http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 http://en.opensuse.org openSUSE Community Member Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-user-list mailing list
