Monitor recommendations?
Monitor recommendations? Daniel Smith 04 Nov 10:19
  Monitor recommendations? Daniel Smith 04 Nov 11:46
   Monitor recommendations? Liam R E Quin 04 Nov 15:26
Daniel Smith
2012-11-04 10:19:04 UTC (over 12 years ago)
Hi all.
I know this is kind of off topic from Gimp, but I am right now looking around at getting a new monitor and since I know obviously this list has as lot of graphics and image specialist type people on it... I am looking for the cheapest and best monitor I can get my hands on. So far I have seen as the best deal the Asus VS239HP for about 175 bucks US. http://usa.asus.com/Display/LCD_Monitors/VS239HP/ but as I am (still) using my old fine pitch CRT monitor any advice would be welcome.
I realized when I went to the Frys store here in Houston I had never even looked at a LCD/LED one. Some of them were pretty crappy compared to the old Viewsonic .25 dot pitch etc...
Thanks for any help.
Dan
Daniel Smith
2012-11-04 11:46:47 UTC (over 12 years ago)
Hi all.
Dan
Liam R E Quin
2012-11-04 15:26:17 UTC (over 12 years ago)
Some things to look for -
. contrast ratio (higher is better)
. IPS screens generally have the best colour fidelity but cost more . many LCD/LED screens have only 6-bit colour, so e.g. 64 levels of blue. Others have as high as 10 or 11 levels (per channel), but cost more.
. some monitors have a USB hub, some also have speakers built in, but the more they spend on add-ons, the less care they take over the monitor part for a given price. The USB hub is a useful addition though. . check it comes with cables! (see below)
.25mm is about 100dpi. You can get 150dpi monitors fairly easily, but watch that you need a video card and cables that can drive them.
Monitors today may or many not include a VGA port, so after you choose a monitor you might need to spend $50 or more on cables and adaptors. For high-fidelity colour you probably want the connection called "DisplayPort". For anything over 2,000x1000 pixels or so, you may need a dual-slot video card and a spcial DVI cable, or DisplayPort. Not all DVI cables will work.
I have a Dell 24" monitor that is not perfect but is better than anything I could buy locally (I tried!).
Liam
