"Virtual" rescale
"Virtual" rescale Johannes Bauer 02 Nov 22:19
  "Virtual" rescale Liam R E Quin 02 Nov 22:20
   "Virtual" rescale Johannes Bauer 02 Nov 22:31
    "Virtual" rescale Alexandre Prokoudine 02 Nov 22:41
     "Virtual" rescale Johannes Bauer 03 Nov 10:59
      "Virtual" rescale Alexandre Prokoudine 04 Nov 03:02
Johannes Bauer
2012-11-02 22:19:46 UTC (over 12 years ago)
"Virtual" rescale
Hi list,
I have a question and am sure it has been asked before -- but I cannot seem to find the correct search terms.
Is it possible to "virtually" rescale layers in the Gimp? Or is this planned? Because it would be an awesome feature.
What I mean is this: When you "virtually" rescale a layer, everything behaves as if it were a normal layer rescale operation, but internally the GIMP remembers the original image size. This means if I change my mind later and want to resize again (make it bigger for example), I don't lose quality. Or is this maybe already be possible somehow and has evaded me?
Best regards,
Johannes
Liam R E Quin
2012-11-02 22:20:53 UTC (over 12 years ago)
"Virtual" rescale
Not currently - if you want this a lot, check out Inkscape.
Liam
Johannes Bauer
2012-11-02 22:31:47 UTC (over 12 years ago)
"Virtual" rescale
I know Inkscape and use it a lot -- for very different tasks, however. For raster image manipulation, Inkscape just doesn't cut it. I use it for all my vector graphics work. They're two *very* different programs, all in all.
By "not currently" -- which question did you answer exactly: Is it not currently supported or not currently planned?
Best regards, Joe
2012-11-02 22:41:02 UTC (over 12 years ago)
"Virtual" rescale
Not currently supported
Johannes Bauer
2012-11-03 10:59:29 UTC (over 12 years ago)
"Virtual" rescale
Has this feature been requested or is it worth filing a enhancement request at the bugtracker?
Regards, Joe
2012-11-04 03:02:56 UTC (over 12 years ago)
"Virtual" rescale
This "feature" is going to be an inherent part of the new non-destructive workflow, where every change can be undone or adjusted across sessions.
