background question
background question Chrispy 25 Oct 11:10
  background question Daniel Smith 25 Oct 12:01
  background question Michael Natterer 25 Oct 12:35
   background question Patrick Shanahan 25 Oct 12:38
2012-10-25 11:10:03 UTC (over 12 years ago)
background question
Hi
I am trying to remove the background of an image I have scanned of a Newspaper. The paper was thin and the back side of the paper is visible on the image. Is there an easy way to remove this?
The reverse image is also visible over the main image I am looking at (the image is a News Headline, not a Picture.
Any advice would be greatly appreciated.
All the best
Chris P
Daniel Smith
2012-10-25 12:01:54 UTC (over 12 years ago)
background question
the best way i can think of would be to put a backing on the paper, not to affix it but just lay it behind the newspaper, when you scan it so the light doesn't emanate the paper so you don't see the other side?
just my 2...
dan
On 10/25/12, Chrispy wrote:
Hi
All the best
Chris P
-- Chrispy (via gimpusers.com)
gimp-user-list@gnome.org
Michael Natterer
2012-10-25 12:35:11 UTC (over 12 years ago)
background question
On Thu, 2012-10-25 at 13:10 +0200, Chrispy wrote:
Hi
If you can, scan again, and put *black* paper on top of the other side while scanning.
--mitch
Patrick Shanahan
2012-10-25 12:38:46 UTC (over 12 years ago)
background question
* Michael Natterer [10-25-12 08:36]:
That *and* pick a black point when scanning. It will make the text that does "bleed thru" appear much lighter.
Then play with the contrast of the product.
